Yet another Volume controlers and source selections - Page 30 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th September 2010, 04:28 PM   #291
Leon08 is offline Leon08  Germany
Banned
O.K, now I changed something and it does compile, but it's working not properly.If I choose SIRC im setup menu then it does not react on buttons.Strange.I must have overlooked something.
And here is my preamp, if you don't know:
http://www.freewebs.com/eduard7/index.htm
Old 28th September 2010, 06:14 PM   #292
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Hi Leon08,
Not sure but in the first 7 loop ( Ir_cmd )you OR with 0x40 I think its 0x20
For ir_add we basically perform the same operations only our loop is only 5 times and we OR with 0b00010000 instead of 0b0100000. After these actions are performed we assign the values of ir_cmd and ir_add to the global variables my_cmd and my_add and then return to our main program where the values are displayed on the LCD display
Code:
for 7 loop  -- repeat 7 times for command
  ir_cmd = ir_cmd >> 1
-- if it was skipped or is done ORing then shift over the 1
 while(ir_pin == high) loop -- wait for it to be low and reset the counter
 lTime = 0
 end loop
        while(ir_pin == low) loop -- while the pin is low which is our pulse count
            lTime = lTime + 1    -- increment every 200uS until pin is high
            delay_100us(2)    -- 200uS delay
            end loop
        if (lTime >= 6) then ir_cmd = (ir_cmd | 0x40) end if
--   If its high then OR a 1 in else skip
--   if its less than 6 its a 0 so dont OR it
end loop
Well just a idea
Link to info code
/ Kim
Last edited by FarmTech; 28th September 2010 at 06:30 PM. Reason: TypO in the QUOTE its OK with 0x40
Old 28th September 2010, 06:37 PM   #293
Banned
You think it should be 0x20 and not 0x40? Maybe you are right, but my current problem is of another nature.
Old 28th September 2010, 06:45 PM   #294
FarmTech's Avatar
No 0x40 is OK it was a TypO in the quot only , when i look at the sirc.jar it is 40 ...
When I added the Vu meter I got problems to but this was the RC5 interrupt in bascom
so I made the RC5 code and did not use the GetRc5 command then it works
Is the SIRC called all the time ?
or just some times else it can hang in Sirc and then buttons dont react
Old 28th September 2010, 09:05 PM   #295
Banned
Yes, now I understood what the problem is, but I don't know how to solve it.If "eval_sirc" is executed, then it hangs.
Old 28th September 2010, 11:36 PM   #296
FarmTech's Avatar
Did you steup
pin as Input and set pin high ?
In Bascom I set as input and set pin High then it works
only pull low if ir is send
Old 29th September 2010, 01:02 PM   #297
Banned
Well, O.K it works when the ir pin is high, but what if somebody will not insert the ir receiver IC?Then it will be permanently low and it will not work.
Old 29th September 2010, 02:59 PM   #298
FarmTech's Avatar
Cant Pic set pin high intern if this is a input pin ?
or ad a pullup 10K res to +5v to Ir_pin
Old 29th September 2010, 08:01 PM   #299
Banned
This is crude way of doing this, but I wanted to do it more elegant.Somehow it's done with rc5 decoder.It does not hang even if there is nothing connected to the input pin.I want to do this similar, but I don't understand how it works.
Old 29th September 2010, 08:19 PM   #300
FarmTech's Avatar
Okay, Then you must see what lrc5ok do and make it in Sirc
its just a bit that is set if a correct Ir code is sent
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
Copyright ©1999-2017 diyAudio
