Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th January 2010, 12:52 PM   #101
Vikt0r is offline Vikt0r  Ukraine
Send a message via ICQ to Vikt0r Send a message via Skype™ to Vikt0r
Danzup,
please - as I am dumb in coding so far - what code has to be added in order to add one or two more inputs - could you advise? Apart from changing the "case" selection, any other definition?
Thanks!
Old 25th January 2010, 06:40 PM   #102
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by Vikt0r View Post
Danzup,
Thanks!
Say for which firmware do you want to do modification and I will show you how .
There are not better tube than 6P3S and 6N2P for my ears !
Old 25th January 2010, 07:01 PM   #103
In post #25, the 8515-PGA2310, +31.5 dB version...
Thanks!
Old 27th January 2010, 04:43 PM   #104
Thanks!
Hey, danzup! Did you forget about me?
Old 28th January 2010, 06:38 AM   #105
danzup's Avatar
Sooory , been a little busy right now .
Here the code modified :
Old 28th January 2010, 08:51 AM   #106
If Inp_sel = 32 Then
Lcd "Aux2 selected"
End If
Lcd "Aux3 selected"
I assume it's a mistake here, should be 64 for Aux3, isn't?
Old 28th January 2010, 09:55 AM   #107
danzup's Avatar
Lcd "Aux2 selected"
End If
Lcd "Aux3 selected"
Yes , I was in hurry !
Old 29th January 2010, 07:30 AM   #108
Danzup, pls. take a look at your PM box...
Old 5th February 2010, 06:25 AM   #109
Hi, Danzup! Hope you still attend this thread from time to time.
I have a question - is it possible to implement encoder in Project Nr.2 (8515+PGA2310)? What has to be done to make it so? On the PCB layout you provided - there is a connection for encoder foreseen, but there's nothing on the schematic. I am especially curious about the code...
Thanks!
Old 5th February 2010, 08:36 AM   #110
danzup's Avatar
Thanks!
Yes . I will post the code in few days : must look where I have saved this variant of software.
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2013 diyAudio
