Yet another Volume controlers and source selections
Old 9th June 2013, 10:07 AM   #881
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Originally Posted by rsavas View Post
What do you think?
>I think I'll skip the big A for AM and use AM PM as normal size
this will look better i think
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 10th June 2013, 09:04 PM   #882
rsavas is offline rsavas  Canada
I am very near sighted, so this was my reasoning for all big digits, although normal size might look better. = Make it a setup option in the code
Old 10th June 2013, 10:03 PM   #883
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Yet another Volume controlers and source selections Yet another Volume controlers and source selections
Why not a 24h clock?
Arne K
Don't believe everything you think...
Old 10th June 2013, 10:08 PM   #884
No particular reason really. It is like I was taught in imperial measuring system in the beginning, so I still think in imperial measurements even though I know metric is the better of the two. Yet another software setup/display option!!
Rick
Old 19th June 2013, 04:32 PM   #885
simonov is offline simonov  Bulgaria
simonov's Avatar
Hi guys. A simple yet bugging question. I'm trying to get inputs switched using a rotary encoder.
now I've searched the Bascom help page regarding encoders. However the explanation there is a bit unclear.
From what I understand, I need two pins, set as inputs and with activated pull-up resistors. That's easy to code. However Içan't figure out the encoders code.
Is there a simple example on how to implement an encoder into the code?
Venci
Old 19th June 2013, 05:53 PM   #886
FarmTech's Avatar
Hi Venci,
check this Bascom and AVR, Encoders
My Web Site
Old 19th June 2013, 06:37 PM   #887
simonov's Avatar
It seems the easiest way is to use this "special" encoder that does not have the A and B channels. However it would be nice to have a part number or some sort of datasheet.
From what I understand it just sets its outputs low for short period of time upon "clicking".
Thanks for the reference.
Venci
Old 19th June 2013, 10:57 PM   #888
simonov's Avatar
Well I think I found the "special" encoder:
SRBM Series - Basic information
It's not an encoder at all. Just a clever endless rotary switch. However those seem to be quite expensive
Old 20th June 2013, 06:19 AM   #889
danzup is offline danzup  Romania
danzup's Avatar
Very simple to use such encoder as yours .
Your encoder is equivalent to 2 switch buttons one for up and one for down .
There are not better tube than 6P3S and 6N2P for my ears !
Old 26th September 2013, 05:54 PM   #890
rob86 is offline rob86
Hi all, can i connect PGA2310 on PC port and the Display on PB port to Atmega8515?
Like these:
http://oi41.tinypic.com/1ilxrp.jpg
by changing pin order in Bascom !?
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
