Yet another Volume controlers and source selections
Old 23rd February 2013, 05:45 PM   #831
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
yes kim is right
Old 24th February 2013, 08:55 PM   #832
RS232 is offline RS232  United Kingdom
Got everything wire up and ready for testing but...
Having trouble programing the Atmega and going to give up for today.
Can any one recommend a cheap programer ? the one I have is one made with just some resistors on a DB25 plug (isp programer).
Ric
Old 24th February 2013, 09:21 PM   #833
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Ric
You need a programmer that can program FUSEBITS !!!
look for USBasp like this
or check bay for a AVR MRKII / USBASP
atmega is default 1 Mhz in clock in most of the code we have clock 8 Mhz
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 24th February 2013, 10:34 PM   #834
Hi FarmTech
Found USBASP on the *bay
Ponyprog does fusebits.
I have the freeware version of Bascom AVR but apparently it doesn't take files bigger then 4K and I really don't want to pay for something I'm only planing to use once.
Ric
Old 25th February 2013, 04:04 AM   #835
Junie is offline Junie  Philippines
LCD panel assembly.
Instead of using a transparent CD case, i use a glass for the window cover.
Old 25th February 2013, 06:50 AM   #836
danzup is offline danzup  Romania
danzup's Avatar
Hi FarmTech
Ric
If you only burn the bin or hex you do not need something else , only for compiling more that 4K you need licence .
You can ask someone that have licence for Bascom to do the firmware and you only program using Bascom and USBASP .
There are not better tube than 6P3S and 6N2P for my ears !
Old 25th February 2013, 10:06 AM   #837
Hi Danzup,
any provision to add a trigger supply section? to control the amplifer on/off?
BR,
Junie
Old 25th February 2013, 10:15 AM   #838
tvicol is offline tvicol  Romania
tvicol's Avatar
Yet another Volume controlers and source selections Yet another Volume controlers and source selections
Originally Posted by Junie View Post
Hi Danzup,
BR,
Junie
Is already included in current firmware v3.5
There are two open collector transistors for amplifier/preamplifier power On/Off and tube plate delay (see schematic J7 connector).
All you need is to connect them to an adequate relay.
Tibi
Vicol Audio
Old 25th February 2013, 10:28 AM   #839
Thanks Tibi, so a 5v relay will do?
Old 25th February 2013, 10:42 AM   #840
tvicol's Avatar
Yes, but choose the proper relay up to your amplifier power.
regards,
tibi
Vicol Audio
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
