Yet another Volume controlers and source selections
Old 22nd February 2013, 02:36 AM   #821
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Hi aditya,
I dont have the code you got for tda7439 & SI4703 (hdd crash)
If you have them mail it and schematic of board for buttons ect
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 22nd February 2013, 04:06 PM   #822
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
i ahd the code of si4703 but similar to you i had suffered a backup hard drive failure along with loos off my Flamingo flying pics.... they were beautiful...
Old 22nd February 2013, 04:53 PM   #823
RS232 is offline RS232  United Kingdom
Finally got the time to do something with my volume control.
Got it out of my shed and going to solder 2 buttons and wire everything to the atmega.
And still need go get a programer for it (Atmega8515 and Atmega16)
Ric
Old 22nd February 2013, 05:49 PM   #824
Hi Kim , I have mailed you a code i found for SI4703 but TDA7439 i never got it... so lets see what to do..
Old 22nd February 2013, 11:53 PM   #825
FarmTech's Avatar
Missing info about setup of ports and pins for TDA
My Web Site
Old 23rd February 2013, 01:16 AM   #826
hii we had kept TDA7439 on Atmega8 , i will give you the schematics for TDA7439 in a days times thanks.
Old 23rd February 2013, 08:49 AM   #827
Hii this is what i have of TDA7439's processor side schematics.
I also think we will need M32 or a bit larger one since Si4703 was bigger one compared to TDA7439's routine
i would like to keep the TDA7439 as it is and add one more switch for radio, and a rotary encoder to trune the radio.
so that would make 2 rotary enocder and 2 switchs.
Old 23rd February 2013, 01:37 PM   #828
atupi is offline atupi  Romania
I was looking to this display:http://www.mouser.com/ds/2/291/NHD-2...UCY3-52838.pdf
and this one: http://www.mouser.com/ds/2/291/NHD-0...-AB5-51365.pdf
Could someone more knowledgeable to tell me if they would work in the ATMEGA8515-PGA2310 configuration discussed here ?
The standard 16x2 display that i use is a bit hard to read from more than 2 meters.
Old 23rd February 2013, 03:42 PM   #829
yes in parrallel mode it should work
Old 23rd February 2013, 04:36 PM   #830
FarmTech's Avatar
Before you go get a OLED Display Module :
check if the controller can be used in bascom
standart is HD44780
there is a lot of OLED Display that do not work as standart !!!!!
see BASCOM-AVR
why not try find 16x2 large/big charset lcd on ebay ect
My Web Site
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
