Yet another Volume controlers and source selections
Old 26th December 2012, 06:41 PM   #781
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Originally Posted by krojo View Post
it is possible to use the second encoder only to change the inputs and use to encoder button to mute for atmega8515 and pga2311?
I think we only have 1 encoder on the board ,
so i dont get what you like to change
can you explain it more
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 26th December 2012, 07:56 PM   #782
krojo is offline krojo  Poland
We have encoder to volume control with button but isn't used. I'd like to use this button to mute. Second encoder or rotary switch use only to change source. I need 3 pins in atmega but don't known with to use. See part control on schematic. Of course we need to modify the program.
Sorry for my english
Old 26th December 2012, 08:11 PM   #783
FarmTech's Avatar
You have to move IR-diode(RC5) to other pin like PC.7
and use INT1 (PD.3) for new encoder + PD.5 or PD.6 for encoder pin
same way as we use it for encoder on INT0
In one of my PGA2311 versions I have MUTE & ON/OFF in same button
short press MUTE long Press ON/OFF
this way you can free up 1 more pin if needed
What version of software for 8515 do you use ?
there is so many versions
My Web Site
Last edited by FarmTech; 26th December 2012 at 08:39 PM. Reason: spelling of cause :)
Old 27th December 2012, 02:07 AM   #784
FarmTech's Avatar
Just a idea how to do it
Code:
Ddrd = &B10000000
Portd = &B01111111
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcd = 16 * 2
Cursor Off
Cls
'rc5  IR OUT to PortC.7
Config Rc5 = Pinc.7 , Wait = 2000
Declare Sub Shiftlf()
Declare Sub Shiftrt()
Declare Sub Volup()
Declare Sub Voldn()                                         '
'encoder 1 volume
Enc_a Alias Pind.1
Set Enc_a
On Int0 Int_0
Enable Int0
Config Int0 = Falling
'encoder 2 select input
Enc_b Alias Pind.5
Set Enc_b
On Int1 Int_1
Enable Int1
Config Int1 = Falling
Enable Interrupts
Do
 If Pind.0 = 1 Then
   'on off
   Waitms 200
 End If
 If Pind.4 = 1 Then
   'mute
   Waitms 200
 End If
 If Pind.6 = 1 Then
   'menu
   Waitms 200
 End If
 'your other code here
Loop
End
'---------shift input Left----------
Sub Shiftlf()
'your code here
Waitms 500
End Sub
'--------shift input right----------
Sub Shiftrt()
'your code here
Waitms 500
End Sub
'-------bring volume up-------------
Sub Volup()
'your code here
Waitms 50
End Sub
'--------bring volume down----------
Sub Voldn()
'your code here
Waitms 50
End Sub
'  ------------------- Int0 & Pind.1  -------------
Int_0:
Disable Int0
If Enc_a = 0 Then
   Call Volup()
Else
   Call Voldn()
End If
Gifr = 64
Enable Int0
Return
'  ------------------- Int1 & Pind.5 ------------------
Int_1:
Disable Int1
If Enc_b = 0 Then
   Call Shiftlf()
Else
   Call Shiftrt()
End If
Gifr = 64
Enable Int1
Return
My Web Site
Old 27th December 2012, 04:49 PM   #785
FarmTech's Avatar
Edit !!!
in Int_1 sub
wrong Gifr = 64
Int1 use Gifr = 128
Code:
Int_1:
Disable Int1
If Enc_b = 0 Then
   Call Shiftlf()
Else
   Call Shiftrt()
End If
Gifr = 128
Enable Int1
Return
My Web Site
Old 27th December 2012, 05:42 PM   #786
Hi
Your idea with MUTE and ON/OFF in the same button is very good. I'm modify schematic can you see thet will by good? I moved IR-diode to PINC.7, RELAY-ON/OFF to PINC.6, for second encoder I use PIND.6, and PIND.5. I try to modify your program form post 370. I don't build this volume control yet but the schematic will be ok I start know.
Old 27th December 2012, 06:09 PM   #787
FarmTech's Avatar
thats wrong you must use INT1 (Portd.3) & PinD.5
thats S+ to INT1 PD.3 and S- to PD.5
I'll check more later on my way home now
My Web Site
Last edited by FarmTech; 27th December 2012 at 06:18 PM. Reason: spelling of cause :)
Old 27th December 2012, 06:22 PM   #788
I change schematic
Old 27th December 2012, 07:32 PM   #789
FarmTech's Avatar
hi,
Ok got some time to look at it now
I moved RELAY_ON/OFF back to PD.6
See addon zip new sch and bas
My Web Site
Old 27th December 2012, 08:35 PM   #790
Ok schematic change as you said, the pbc upload maybe in Saturday
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
Copyright ©1999-2017 diyAudio
