Yet another Volume controlers and source selections Yet another Volume controlers and source selections - Page 78 - diyAudio
Old 10th December 2012, 06:26 PM   #771
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
I tested the code (,wait = 2000) and it works here on a M32 and M8
are you sure you have setup fusebit as internal 8Mhz ?
Low = E4 High = D9
try addon hex compiled with latest Bascom-avr
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 10th December 2012, 06:39 PM   #772
atupi is offline atupi  Romania
I've flashed your sw and the things are much better. I mean when i keep pressed the Vol+ or - the behaviour is normal but when i'm playing prssing alternatively + and - i need to press twice the desired key to obtain the effect. The same with Channel up/down in order to switch between signal sources.
Things are better now
Old 10th December 2012, 07:09 PM   #773
FarmTech's Avatar
Hi, I just programed a ATMEGA8515 wirh the code
and it works OK 1 push on remote step volume up/down and input input up down
this must be your remote that have problem
My Web Site
Old 10th December 2012, 07:18 PM   #774
Well, i'm using an universal controller and i have a list of Philips codes to choose. I will try to program some other codes from Philips list.
Farmech, can i ask some more help or customization?
Normally i push a swich to enter to Souce Select routine and i would like after certain seconds (5-10) to get out automatically from this souce select mode and to stay in volume level mode.
Also the Source Select to be kind of circular menu cd>dac>phono>aux>cd>dac.......
It's hard to do something to memorize the settings after power off completely ?
A big THANK YOU,
Adrian
Old 10th December 2012, 07:36 PM   #775
FarmTech's Avatar
Adrian,
try this for input
Code:
'---------shift input Left----------
Sub Shiftlf:
Call Bklght
If Inp_sel = 8 Then
   Inp_sel = 1
Else
   If Inp_sel >= 1 And Inp_sel < 8 Then
      Rotate Inp_sel , Left
   End If
End If
Porta = Inp_sel
Call Af_sel
Waitms 200
 W = 0
 Timer1 = W
End Sub
'--------shift input right----------
Sub Shiftrt:
Call Bklght
If Inp_sel = 1 Then
   Inp_sel = 8
Else
   If Inp_sel >= 2 And Inp_sel < 9 Then
      Rotate Inp_sel , Right
   End If
End If
Porta = Inp_sel
Call Af_sel
Waitms 200
 W = 0
 Timer1 = W
End Sub
about the return to volume
you can use the backlight time
addon file with the update
File Type: zip adrian encoder 4 intrari_2077_update.zip (10.7 KB, 76 views)
My Web Site
Old 10th December 2012, 07:53 PM   #776
Circular meniu for souceselections works fine.
Regarding getting out from Source select following thing is happening: i select source> goes automatically out to Adjust Volume and the backlight is on every 1-2 sec after few seconds. Also It shows Select input again without any external influention.
For sure it's a bug
PS. Yours are working better than mine Bugs are on mine software
File Type: zip adrian encoder 4 intrari_2077_circular volume.zip (2.9 KB, 79 views)
Old 10th December 2012, 08:00 PM   #777
FarmTech's Avatar
I dont have the bug !! update to latest bascom-avr
see video HERE
download latest file again (adrian encoder 4 intrari_2077_update.zip)
your code its not same code as what I used see diffrens in bas
timer1 start stop
My Web Site
Old 10th December 2012, 08:20 PM   #778
Last question for tonight: wich are the parameters to play in order to have bigger steps for volume up/down (now is 0.5dB) ?
Thank you again for your help!
Old 10th December 2012, 08:24 PM   #779
FarmTech's Avatar
In sub vol up/down you have +1 and +5 this is the steps in volume
Code:
If L <= 86 Then
        L = L - 5  '<<<<<<<<<
        R = R - 5  '<<<<<<<<
        Gain = L / 2
        Gain1 = -96 + Gain
        Call Spio
Else
        L = L - 1' <<<<<<<<<
        R = R - 1'<<<<<<<<<
        Gain = L / 2
        Gain1 = -96 + Gain
        Call Spio
End If
so from this setup volume
-53db to -95.5 it step 2.5db (+-5)
-53db to +10.5db it steps 0.5db (-+1)
My Web Site
Old 26th December 2012, 07:37 AM   #780
krojo is offline krojo  Poland
it is possible to use the second encoder only to change the inputs and use to encoder button to mute for atmega8515 and pga2311?
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
