Yet another Volume controlers and source selections
Old 26th October 2012, 07:45 AM   #751
rondadon is offline rondadon  Germany
Hi there.
I have a SymAsym Amplifier now ready working and I want to implement the feature to change the volume and source over a Remote and Rotate Knobs.
The Volume and Source should be displayed through a LCD or OLED-Display. I have read some of these pages but I dont know If I understood it right.
1.)Is there any Groupbuy to this?
2.)Is this controller changing the sound in any way?
3.)What is the "last" and "best" version to this?
4.)Did I understood it right that the Software-Part is OpenSource (This would be awesome)?
5.)Is this also realizable with a AT90USB162 Dev Board?
Is there any other Project/Board that you would recommend more if I want a Volume (maybe with motorized Potetiometer) and Source selection with remote and Display. I could program an AVR.
Thank you very much for your help in advance.
Greetings from Tschöhrmany!
Ron
Old 26th October 2012, 08:05 AM   #752
tvicol is offline tvicol  Romania
tvicol's Avatar
Yet another Volume controlers and source selections Yet another Volume controlers and source selections
Ron,
We still have boards available for sale at vicol audio : Webshop
In R-2R version the controller is transparent - not changing the sound.
We are using a custom firmware, therefore this in not opensource.
Tibi
Vicol Audio
Old 26th October 2012, 08:17 AM   #753
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by rondadon View Post
Hi there.
Ron
1.) No there is none such .I have posted the integral documentation such as schematics and firmware , and everyone is free to do what he wants and wherever project wants.
2.)There are 2 projects that do not change the sound : that project with alps motorized Potetiometer and that with r2r Volume do not change the sound !
Regardless what other on world said : all cmos/mos/jfet/PGA2310/TDAwhatevernumber Volume have their own sound , like I say dog barks and bear just passed by .....
3.) Project are as their are and if the readers are not confortable with microcontrolers and audio and electronics in general maybe this projects are nor for them .The best I think is the r2r and/or blue velvet motorized Potetiometer project ( but I say that again here).
4.) Yes i posted firmware for everyone to edit / use / modifie as inteded by everyone, there are the source code attached so no problems about modifiing .
There are by years a lot of projects made by exactlly as you requested ,but never posted here , only in romanian forum where now have dissapeared after the server that hosted forum crashed , but if you need : atmel Atmega + LCD + 4 source input select + one motorized Potetiometer + IR i will post this project here . Just say and i will find that schematics and firmware in my backup files and post here.
5.)As it seeems that AT90USB162 is supported by AVR BASCOM it means that this chip can be used on project but there are some modification that must be done . I do not own such chip so it is up to you to try . Say what project do you want to do and I will try to help .
Also : if anyone want to try some Group Buy I will support them with advice and help but cannot make and will not intend to open GB by myself.
Regards ,
Dan Zup
There are not better tube than 6P3S and 6N2P for my ears !
Old 26th October 2012, 09:04 AM   #754
danzup's Avatar
Errata : the firmware of R2R controller is not Open , and I will not post firmware for that controller, as that one is specially designed and writted for Vicol Audio : check webshop
there are ready mounted and programmed R2R Volume controller.
Old 26th October 2012, 10:34 AM   #755
Originally Posted by tvicol View Post
.............We still have boards available for sale at vicol audio : Webshop
click on Shiga infrared remote and it takes me to a CD product.
regards Andrew T.
Old 26th October 2012, 10:41 AM   #756
tvicol's Avatar
For VC scroll down to DanZup R2R / Shunt vollume controller LCD display version.
Tibi
Vicol Audio
Old 8th November 2012, 08:44 PM   #757
atupi is offline atupi  Romania
My finalized preamp in a recycled sat receiver box:
and inside where needs a bit of cable management. Pga 2311 powered from some shunt regulators and a hotrodded DCB1 (Pass&Salas)
Old 13th November 2012, 01:03 AM   #758
kevinkr's Avatar
OT posts removed. Further posts not relating to the original topic will be deleted.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th November 2012, 07:16 AM   #759
ds23man is offline ds23man  Netherlands
ds23man's Avatar
I think this topic should be moved to the Vendor's bazaar because parts of it are clearly commercial. If not, the Hypex Ncore topic should be moved back to Class D!!!!!
Old 18th November 2012, 09:00 AM   #760
Default Help with software
I'm using the software attached and something is wrong and it drive me crazy.
So, when i'm using remote control (Philips) i need to press the key on the remote several times per second to have effect and is very annoing.
This situation is the same if i want to change volume or input.
If i press the button and keep pressed nothing happening.
Please note i'm noob in avr programming.
Thanks!
Adrian
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
