Yet another Volume controlers and source selections
Old 9th April 2012, 04:27 PM   #731
rob86 is offline rob86
I want to make controller version and pga2310 atmega8515. We all components but I need some help with a VFD display!
It's CU20029ECPB-U1J. 2x20 character VFD.
This display has 4 levels of brightness, but do not know how I can change these levels.
Here is the datasheet of display : http://www.meditronik.com.pl/doc/a0-a9999/vfd20x2h.pdf
Can someone help me?
Old 10th April 2012, 04:46 AM   #732
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Hi rob86,
Looks like you can use bascom command LCDCONTRAST
LCDCONTRAST x ' X = 0 to 3
from datasheet SOFTWARE COMMANDS - you have "Brightness Set 0 - 3"
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 10th April 2012, 06:55 AM   #733
It's working! Thank you!
Old 10th April 2012, 04:10 PM   #734
atupi is offline atupi  Romania
Hi Rob, nice to hear another project finished and working. I plan to build one identical to yours. Could you tell me wich pcb-s did you used?
Thanks!
Old 10th April 2012, 08:56 PM   #735
FarmTech's Avatar
did you read post #3
Think most projects is done like this for M8515
My Web Site
Old 11th April 2012, 08:12 AM   #736
Of course i have read almost all of messages. I was hoping to find a project to etch my own pcb's.
Old 21st June 2012, 03:47 AM   #737
emuman100 is offline emuman100  United States
This is quite a long thread! is there a group buy for any of these projects that is still active? What is the best method for volume attenuation? Is it stepped resistors or using a chip? I'd like a good volume control for my Phase Linear 400 Amplifier.
Old 21st June 2012, 04:06 AM   #738
didiet78 is offline didiet78  Indonesia
Not that long. Contact tvicol diyAudio - View Profile: tvicol
Didiet
Old 27th August 2012, 07:21 AM   #739
xaker66 is offline xaker66  Russian Federation
Hello Wanted: Digital control with a chip on the controller PGA2310, with output to LCD display. In this forum, I've seen similar. Could you please help me to give firmware scheme and seals in one file, I'm pretty hard to read the whole forum because I do not know much English. I live in Kazakhstan. If it is possible for soap xaker.66666@mail.ru. Thanks in advance.
Old 17th September 2012, 09:01 PM   #740
My project is finished now and partially working. Not tested yet the remote control part but so far the most annoying thing is that the LCD backlight is not working. When i'm shorting E and C of transistor that is responsible with backlight i have light. Also on the pic 17 of uC wich is triggering the transistor i'm not measuring any change with DMM. I have tried all software and same result, not backlight. Any ideas ?
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
