Yet another Volume controlers and source selections
Old 14th January 2012, 05:19 PM   #711
tvicol is offline tvicol  Romania
tvicol's Avatar
Yet another Volume controlers and source selections Yet another Volume controlers and source selections
Originally Posted by Jempie View Post
it's the same board as you can buy from tibi.
turn the volume up, and disconnoct the source you will hear hum
Jempie,
There are two 0 ohm resistors on the board R42L and R42R.
These are connecting VC ground to VC power suppply ground.
Normally these resistors shouldn't be connected. However, we have provided them in case you want to make a single ground star for all power sources in your design.
If these resistor are not connected, than you should search for hum elsewhere, because in this case VC is completely isolated from any power supply.
Tibi
Vicol Audio
Old 21st January 2012, 10:54 PM   #712
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Hi Jempie,
Did you cure the hum problem ?
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 6th February 2012, 03:45 AM   #713
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
Default pcb layout for TDA7439DS
hi
made this pcb for replacing my pga2311 ( vvvvvvvery sweet chip) card, since things are modular in my amp.. i can relace the processor, amp, power filters. so even my preamp is sort of modular...
anyways just posting the pic of the pcb... let me how to improve it more.. if possible..
yes i know i should have used mkt capz.... but .... i wanted to make it small and couldnt source all the cap in same chemical family in bombay market.. anyways.. did what i could
Old 14th February 2012, 07:54 PM   #714
tvicol's Avatar
For those who like to use avrdude, I have added a small how to:
http://vicol-audio.ro/img/volume-con...r_firmware.pdf
Also more documentation is available at vicol audio : r-2r volume controller
Tibi
Vicol Audio
Old 18th February 2012, 04:30 PM   #715
TBKK is offline TBKK  Germany
Farmtech
According to the regular r2r schematic the resistors are
R30-R40
10k 2.5k 5.8k 15k 53k 390k
R31-R41
82k 47k 27k 16k 12k 10k
If you compare link Logarithmic Attenuator Calculator
The value are different
10k 8k2 5k6 3k9. I have the Same problem as jempie
Old 19th February 2012, 07:53 AM   #716
FarmTech's Avatar
Hi
I did not make the electronic part of this only made some software (addons) for it
so better ask one that know more about R2R than I do
My Web Site
Old 19th February 2012, 09:52 PM   #717
I hate also that the volume at "0" is not really quit
Old 22nd February 2012, 01:42 PM   #718
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
TBKK,
use 7relais R/2R with "-127dB" at "0" volume level like i did
Or recalc R/2R for -127dB with 2dB step
Old 23rd February 2012, 08:35 AM   #719
Jempie is offline Jempie  Indonesia
Tbbk,
I have the same problems, clinking is
reduce thanks to Pryanick.
Will try now to recalculate the resistors
With steps of 1.5 dB or 2 dB
still is not easy to make it right
Old 23rd February 2012, 09:11 AM   #720
Pryanick's Avatar
Jempie,
the only way to do it right is do it ones in a proper way
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
Copyright ©1999-2017 diyAudio
