Yet another Volume controlers and source selections
Old 7th January 2012, 11:47 AM   #691
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Originally Posted by Jempie View Post
Finally the volume control work thanks to Farmtech.
only the LM1117DT-5.0 gettig hot after 5 min the display goes down.
I think you draw to muts current via LM1117DT-5.0
Or your input Volt is to high
can you post the sch or send it via email
Old 7th January 2012, 12:06 PM   #692
Jempie is offline Jempie  Indonesia
http://www.vicol-audio.ro/img/volume...d_20101406.pdf
Old 7th January 2012, 12:11 PM   #693
FarmTech's Avatar
ok backlight maybe to high
Old 7th January 2012, 01:45 PM   #694
Framtech, voltage 4,65 volt
Old 7th January 2012, 02:53 PM   #695
didiet78 is offline didiet78  Indonesia
I think Farmtech mean not voltage but cuurent for LCD backlight. Add resistor 100-470 to Pin A or K. Or try omit Q7 or R10 first to check.
Old 7th January 2012, 02:58 PM   #696
FarmTech's Avatar
what trafo supply volt (AC) do you have and mA ?
can you messure volt before LM1117DT-5.0 and after (4,65 volt)
did you check board for soilder errors ?
@ didiet78 : sorry yes of cause it was current i mean
some backlight use alot of current if setup is wrong and then LM1117DT is working to hard
Old 8th January 2012, 09:27 AM   #697
FarmTech, yes i have check more then 10 times the components
there is no difference between schematic and board.
i use winstar WH1602L-TMI-ET display with no resistors on A-K for the blacklight
i use 14 V AC is this to high?
Old 8th January 2012, 10:12 AM   #698
FarmTech's Avatar
Well
14VAC = about 20Vdc
9VAC = about 12VDC
try a lower VAC I think thats why you have heating problems
see datasheet Page 4 Output Voltage
it show max 12VDC for high current use
Old 10th January 2012, 03:21 AM   #699
Danzup, in post http://www.diyaudio.com/forums/analo...ml#post2074525 can i just change PGA2310 with PGA2311 and change analog supply with +/-5V without change the HEX file?
Didiet
Old 10th January 2012, 06:00 AM   #700
tvicol is offline tvicol  Romania
tvicol's Avatar
Yet another Volume controlers and source selections Yet another Volume controlers and source selections
Jempie,
LM1117DT is a low drop regulator. Use a trafo with min 6V ac - max 9V ac.
Tibi
Vicol Audio
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
