Yet another Volume controlers and source selections
Old 13th January 2010, 09:04 AM   #51
Vikt0r is offline Vikt0r  Ukraine
Send a message via ICQ to Vikt0r Yet another Volume controlers and source selections
Hi danzup!
Others also complained on my I'm reading theor thoughts
You'd probably laugh at me, but the main reason I don't want to use perfboard for this project - is that I'm saving my available perfboards for "modeling" projects (I'm greedy to spend money at them ) and because otherwise I have everything available for it, so can make it without attending a shop, also making a PCB from the scratch takes me max. 2 hours - so why wouldn't I make this "as should be" from the beginning? Moreover, SMD components would require no drilling... Moreover - I've got them already
Old 13th January 2010, 01:22 PM   #52
coolnose is offline coolnose  Europe
Originally Posted by danzup View Post
On the first page project nr.3 :
http://www.diyaudio.com/forums/analo...elections.html
( price for : kit r/2r atmega16 / 4 input without transport to USA is 53 euro , please any other info in pm )
But if you do not like the fade and discrete mechanical sound of relay (this do not propagate to speakers ! ) this is not for you !
In path of audio signal there are only at max attenuation 6resitors and have the most transparent sound of a passive preamplifier .
Hi danzup,
haven't heard from you anymore, but I am still interested in the kit.
If you have decided not to offer them is pretty ok, I would then start the project using your PCB design... and probably be asking a lot of questions during the build time...
Max
Old 13th January 2010, 01:26 PM   #53
After reading the lasts posts properly I thing I was too fast myself as well... I'll just be looking here from time to time.... and wait for the magic PCB...
Old 14th January 2010, 12:20 PM   #54
Originally Posted by Vikt0r View Post
Atmega in QFP
Need to add some clarity, my Atmega is PLCC, not QFP.
Sorry, was my mistake, not too much difference in the PCB though.
Old 14th January 2010, 06:24 PM   #55
dobrivoje is offline dobrivoje  Serbia
Default Pcb
Now I work very slow. I spent a lot of time reading Romanian thread and I've made some PCB's for my project. Actually, seven (control board, power supply, pony prog, front board for display, LCD and pushbuttons, two boards for inputs and two boards for volume.
I understand some people need PCB's. I can't help Vict0r, but coolnose can use my design. It's not optimized because I don't work professionally. I just used halves of Euro format. I can also send design of other PCB's.
I hope in next ten days I'll have my boards completed and tested.
Old 14th January 2010, 07:41 PM   #56
Nevermind, dobrivoje!
Considering that danzup's friend did not post anything in reply to our requests, I also started developing boards. At first I made a copy of design of the initial board (with DIP casings) in my favourite design tool, now at the next step - I'm making a dumb conversion of the board design in this same tool to PLCC/SOIC. So far seems, that I would need to completely remake the design for this purpose, which is also not a big problem (weekend is coming). Once I'm ready, I'll also share this design (hope you okay with this, danzup?).
Old 15th January 2010, 07:41 AM   #57
danzup is offline danzup  Romania
danzup's Avatar
Very ok !
Good luck to both Vikt0r and dobrivoje and waiting for both to post here your work !
Soon I will add an passive baxendall tone / volume control project I am working now .
Also : for everyone who make one of projects I will offer full support ( on little time I have now available ...) .
There are not better tube than 6P3S and 6N2P for my ears !
Old 15th January 2010, 08:26 AM   #58
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
Default Pga2310 sol16 pcb
Hi
2 Vikt0r
If its not too late I can post here my PCB version under PGA2310 danzup project. But I dont use any specific soft for PCB tracing, I draw all my PCBs in CorelDrawX3.
If its ok - just ask an I publish it here today in the evening.
2 danzup
"...passive baxendall tone / volume control..." - oh, yeahhhhh!
Sounds good!
I like it even without schematic
...particularly passive baxendall tone control
Old 15th January 2010, 09:11 AM   #59
tvicol is online now tvicol  Romania
tvicol's Avatar
Yet another Volume controlers and source selections Yet another Volume controlers and source selections
Thanks to danzup and jkraxi, this project is an open-source now.
You have schematic, gerbers, pcb layout, atmel software for LED and LCD display.
:: vicol audio :: R-2R volume controller ::
Enjoy !
Tibi
Vicol Audio
Old 15th January 2010, 09:49 AM   #60
danzup's Avatar
Enjoy !
Tibi
Yes , project nr.3 also go open source and launched group buy for new pcb :
GB for R2R audio volume / input selection pcb
Thanks all !
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
