Yet another Volume controlers and source selections
Old 15th December 2010, 05:42 PM   #441
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
hii this is my pcb layout with 3 relays and a seperate board for avr along with provision for future crystal ... just in case
Old 20th December 2010, 07:50 AM   #442
TBKK is offline TBKK  Germany
I want to build the one with motordrive see #1. but the software only indicate
volume up and volume down and input selection. can it be change with the right position of the volume.
Old 20th December 2010, 09:41 AM   #443
danzup is offline danzup  Romania
danzup's Avatar
No , because the potentiometer is actionable manually and microcontroller is not aware of that button position .
There are not better tube than 6P3S and 6N2P for my ears !
Old 20th December 2010, 09:56 AM   #444
yes, but is it not possible to count the puls to the motor? and remember this
Old 20th December 2010, 10:13 AM   #445
danzup's Avatar
Only if you reset always (every time you power on the amplifier ) to 0 the potentiometer and if you know the potentiometer constant .
It is not feasible this way ...
And the motor is DC not pulse !
Old 20th December 2010, 10:27 AM   #446
danzup,
if i connect an encoder with a belt to the potentiometer that way it will help?
Old 21st December 2010, 12:26 AM   #447
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
danzup,
It can be done ,
IF you connect a 10K potmeter with a belt to the potentiometer, then the potmeter to GND (ADC) +5V
The use 1 of the ADC channals to read the volt on the potmeter
and convert it
The adc channel read 0 - 1023 then convert it into a volume db table for read out on lcd
I did not say its easy but it can be done
Old 22nd December 2010, 01:08 PM   #448
vzs is offline vzs  Europe
Originally Posted by FarmTech View Post
Here is the bugfix for direct select input 4
Thanks! I will try it only after Xmas as there are other stuffs to do before
Old 23rd December 2010, 01:24 PM   #449
Geosto is offline Geosto  Netherlands
Danzup hi,
First my compliments for this beautiful volume controller
I would like to build Project No 3
but I do have a few questions.
I understand that the input impedance is 20K.
What values do I need if I want to reach 100K?
I am also looking for the Microcontroller but can only find this one ATMEGA16-16PU.
Is this the right one?
Regards George
Old 28th December 2010, 07:59 AM   #450
danzup's Avatar
Originally Posted by Geosto View Post
Danzup hi,
Regards George
Hi , for calculating the part of r2r volume look here :
Resistor-Switch Attenuator Networks for Audio Volume Control
and for some theory about how is working everything look here :
you can use the soft ( including Farmtech special firmware ) with ATMEGA16-16PU without modification .
Good luck !
And a Happy new year for all !!!!
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
