Yet another Volume controlers and source selections
Old 18th November 2010, 08:01 PM   #411
chiily is offline chiily  United Kingdom
Originally Posted by FarmTech View Post
Did you test the code in post #349
here you can edit input text and muts more
Ah yes, missed this one...
Just flashed the ATM16 and your firmware works wonderfully. Love the layout and the fact that I can edit the Input labels.
Couple of bugs:
I don't have a RC5 compatible remote atm. So when I go into the menu to set-up the RC5 remote I can only use the Select button to get back to the main view. Returning to the main menu causes the display to return the right channel to whatever it was, but sets the left channel display to 0.
Again, as I don't have a remote once I go into the Input labelling menus the only way out is to power down and power back up the board. The select button should really take it back to the main menu/view.
I've also found that sometimes the R and L labels on the volume bars change to V and S.
But over all this is a great piece of code Thanks for pointing it out to me.
Will the .bas ever be released?
Garf.
Old 21st November 2010, 03:29 AM   #412
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Hi, Tanks for the feedback on the program
At the moment Iam adding a radio chip and the Eq chip to the code
this way I have my preamp with buildin FM radio and 7 band Eq on lcd
I allso change to M32 for more programming space for all the addons I made
The bas file is not public
but if you go back to post ¤3 then you can make change in the bas file to fit your options
Kim
Old 24th November 2010, 08:23 AM   #413
I'm just picking my way through the learning curve of using an ATMega16 microprocessor. This week's lesson was that the JDAG interface needs to be disabled for the relays to work correctly. All done through fuses...
Problem this week is the IR interface. For some reason I can't get the IR to work at all. The interface looks simple with the IR device being connected to INT1/PD3. I've tried four different remote controllers and even a universal controller, but no luck. Any ideas?
Garf.
Old 24th November 2010, 08:28 AM   #414
FarmTech's Avatar
RC5 remote test
Try my RC tester
remember to setup M16 to run internRC 8Mhz else the RC5 dont work !!!
Old 24th November 2010, 08:48 PM   #415
RC5 remote test
Try my RC tester
Yes I have the clock set to 8Mhz. CKSEL3:0 is set to 0100. SUT1:0 is set to 10. BODLEVEL and BODEN both set to 1 (unprogrammed). So the low fuse is 11100100 = 0xE4.
Bit Bit No. Description Value
BODLEVEL 7 Brown-out Det. trig. level 1 (unprogrammed)
BODEN 6 Brown-out Detector enable 1 (unprogrammed)
SUT1 5 Select start-up time 1 (unprogrammed)
SUT0 4 Select start-up time 0 (programmed)
CKSEL3 3 Select Clock source 0 (programmed)
CKSEL2 2 Select Clock source 1 (unprogrammed)
CKSEL1 1 Select Clock source 0 (programmed)
CKSEL0 0 Select Clock source 0 (programmed)
The high fuse looks like
OCDEN 7 Enable OCD 1 (unprogrammed)
JTAGEN 6 Enable JTAG 1 (unprogrammed)
SPIEN 5 Enable SPI Downloading 0 (programmed)
CKOPT 4 Oscillator options 1 (unprogrammed)
EESAVE 3 EEPROM memory is preserved 1 (unprogrammed)
BOOTSZ1 2 Select Boot Size 0 (programmed)
BOOTSZ0 1 Select Boot Size 0 (programmed)
BOOTRST 0 Select reset vector 1 (unprogrammed)
11011001 = 0xD9
I may have done something a little wrong, but I'm not sure...
Should the IR device be 36khz or 38khz?
The link to the RC tester just loops back to this page
Cheers
Garf.
Old 24th November 2010, 09:04 PM   #416
FarmTech's Avatar
my fuse is :
HIGH : DF
LOW : E4
Cheers
post #271 page 28
36khz
Old 29th November 2010, 08:04 PM   #417
Hats off to Farmtech...
I finally found a controller code that works and with Farmtech's firmware that allowed me to change the RC5 codes for volume/input selection I now have a fully working and remote controllable volume for my B4 pre-amp.
Thanks again Farmtech.
Maybe Tibi and yourself should look at working on the next release of firmware for the VC controller?
Cheers.
Garf.
Old 29th November 2010, 08:10 PM   #418
FarmTech's Avatar
Cheers.
Your weclome :-)
Who is Tibi ?
Old 30th November 2010, 06:31 AM   #419
danzup is offline danzup  Romania
danzup's Avatar
Your weclome :-)
Who is Tibi ?
My best friend who is in charge with assembling and selling kits and pcb on his online web store .
We have a lot of project on going .
vicol audio : high-end amplifiers & audio tuning
... chiily does not know that firmware was write by me and I think he does not read the whole thread from the beginning ...
There are not better tube than 6P3S and 6N2P for my ears !
Old 30th November 2010, 03:55 PM   #420
FarmTech's Avatar
I did add the info so everyone can see You did make the software and this is a mod of your nice code
Here is a update for Danzup´s Ir Volume Control Ver.1.6(c) (FarmTech) NO VU METER
maybe I can make it more clear next time
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
Copyright ©1999-2017 diyAudio
