Yet another Volume controlers and source selections Yet another Volume controlers and source selections - Page 4 - diyAudio
Old 22nd November 2009, 10:02 PM   #31
joemana is offline joemana  United States
Danzup,
Since I have no idea on which of this controler to pick, which one do you recommend if I want the best of your design? My needs is the one that can be used with universal remote, display and four inputs?
Since you have the r/2r kit, how much is the complete kit including shipping to U.S ? Where can I find the details of r/2r?
Thanks,
Joe
Old 23rd November 2009, 12:01 PM   #32
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by joemana View Post
Danzup,
Thanks,
Joe
On the first page project nr.3 :
http://www.diyaudio.com/forums/analo...elections.html
( price for : kit r/2r atmega16 / 4 input without transport to USA is 53 euro , please any other info in pm )
But if you do not like the fade and discrete mechanical sound of relay (this do not propagate to speakers ! ) this is not for you !
In path of audio signal there are only at max attenuation 6resitors and have the most transparent sound of a passive preamplifier .
There are not better tube than 6P3S and 6N2P for my ears !
Old 26th November 2009, 06:09 AM   #33
voxac30 is offline voxac30  Slovenia
Hi!
I,m building tube preamp FVP (Allen Wright) with 4 CCa Telefunken
tubes .I have Alps motor poti with controler ,but will also remote
sources.So I m intersted on your kit ,or only programed IC .I ,m
only analog guy and have no skills in digital el.I have some questions
1: is posible to progam 30 -40 sec delay function ( tube warm up)to operate relay for B+
2: analog to that function output mute -when B+ for tube is on
output is on -gnd on output is enabled.
3: duo led aded for status -warm up -red ,operate -blue
What is price for kit with that functions?
voxac30
yeti
Old 26th November 2009, 09:12 AM   #34
danzup's Avatar
Originally Posted by voxac30 View Post
Hi!
voxac30
Yes all of your idea are possible and already implemented in one of my tube amplifier !
On LCD it will appear : " Warming up tube !" U anodic is off and mute is on , and after 60 seconds it will say " Ready !" in this time mute will stay active and only after U anodic is connected the mute relay will be released .
If you do not want to use a LCD please tell and I will provide schematics for led only on front panel .
An atmel AVR programmed with firmware will cost you without transport 5 euro .
For kit : I have an kit with pcb etched on-house using toner transfer technique with 6 input to select , cost without transport : 50 euro (schematics and pcb posted here on first page
1. Volume controller / source selector for motor potentiometer ( like Alps blue velvet ) : )
Old 26th November 2009, 01:35 PM   #35
Hi !
Thanks for answer .I send you private mail for buy controler.
voxac30
yeti
Old 2nd December 2009, 01:52 PM   #36
danzup's Avatar
Originally Posted by danzup View Post
3. Control and audio source selection with relay and r2r volume
- volume with quality MELF resistors for r2r or shunt adjusting
- infrared remote control in the stop / start amplifier
- selection from 4 sources of signal relays
- display with 16 x 2 or 20x2 LCD
- switch and encoder for selections
Firmware for this project (the .bin and .hex files ready for programming the atmega16) .
You must also write 2 fusebits in atmega16 :
- Jtag disable
- Internal 8Mhz RC oscillator
Old 2nd December 2009, 05:28 PM   #37
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
Hi
I soldered volume control with M8515 & PGA2310.
THNX Danzup
Old 3rd December 2009, 08:28 AM   #38
Pryanick's Avatar
Hi
Last weekend I soldered RC5 controled passive preamp with danzup source code from
http://www.diyaudio.com/forums/analo...ml#post1907172
and with schematic from
http://www.diyaudio.com/forums/attac...attiny2313.jpg
I used 2xATtiny2313 and changed source code for both.
One of ATtiny2313 uses for amplifire switching on/off and basscontrol.
Other ATtiny2313 uses only for treble control. It turns on when amplifire is on.
Old 3rd December 2009, 08:30 AM   #39
Pryanick's Avatar
Default RC5 controled passive preamp schematic
Schematic for RC5 controled passive preamp
Old 3rd December 2009, 10:45 AM   #40
danzup's Avatar
Congratulation !
And Pryanick : I like those MLT resistors , give so sweet sound !
I will post some time soft and schematics with one atmega16 with r/2r 6 relay for volume and 7 relay for bass and 7 relay for treble controller (exactly like your but extended for 7 relay each tone control : bass and treble for 0dB in the middle and -5dB, -10dB ,-15dB and +5dB , +10dB , +15dB on both ).
It was made by me in year 2007 but never posted ....
here the schematics :
http://i31.tinypic.com/necfb5.jpg
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright 1999-2017 diyAudio
