Yet another Volume controlers and source selections
Old 20th November 2009, 06:24 AM   #21
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by Pryanick View Post
Hi
I tested firmware today
One question I've got: why only +10db?
Datasheet says that +31.5db max should be.
Danzup, can you fix it please?
Thank you.
I have limited to +10dB because if you do the math when you have on input a CD-player which usually have over 2V on output you will have big distortion because you overshoot the analog power voltage on PGA ( the soft I am using in one of my preamplifier I have build I use limit to 0dB !!! because +10dB tend to be to much) .
But if you want I can rewrite again the soft to reach the 31.5dB !
( Are you sure you want that ? )
Later edit : I have done what you asked about , here is the soft.
There are not better tube than 6P3S and 6N2P for my ears !
Old 20th November 2009, 07:43 AM   #22
danzup's Avatar
Here is a proposition for pcb layout :
Old 21st November 2009, 07:04 AM   #23
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
Hi
I'm going to use passive preamp.
It means signal slackening by 10...20dB. That's why I want to control full PGA2310 dynamic range.
You were right when you said about CD-player with 2v output. 3 years ago I made DAC on CS8416&CS4391A for CD-ROM and I have 1.98v output on it. But in any time I can make volume lower.
Thank you danzup for PCB layout.
I already made my PCB.
Thank you again for the soft and for your help
Old 21st November 2009, 08:17 AM   #24
Pryanick's Avatar
Hi again
There are some errors
Danzup, could you fix it please...
Error : 49 Line : 220 Value doesn't fit into BYTE [256] , in File : D:\...\PGA2310_1_6_D_31_5.BAS
Error : 49 Line : 223 Value doesn't fit into BYTE [256] , in File : D:\...\PGA2310_1_6_D_31_5.BAS
Error : 7 Line : 0 IF THEN expected [ 223] , in File :
Error : 123 Line : 0 END IF expected , in File :
Old 22nd November 2009, 06:06 AM   #25
danzup's Avatar
Hi again
Sorry for error , here are the fixed files for firmware (including .bin ) :
Old 22nd November 2009, 02:17 PM   #26
Pryanick's Avatar
Hi
Thank you danzup for soft - I compiled it with no error.
Perfect!
I have a favour to ask of you to add last feature to this beautiful preamp controller - balance control.
Without balance control we have perfect device. But with balance control it will be brilliant!!!
Can you add this feature please?
Old 22nd November 2009, 04:25 PM   #27
joemana is offline joemana  United States
Hi Danzup,
Are you selling the kit? If you do, how much?
Thanks,
Joe
Old 22nd November 2009, 05:37 PM   #28
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by joemana View Post
Hi Danzup,
Thanks,
Joe
kit would be sweet!
Old 22nd November 2009, 06:28 PM   #29
danzup's Avatar
Originally Posted by jleaman View Post
kit would be sweet!
As you read in this thread I have done by the years a lot of type of controller :
- volume with specialized IC like PGA 2310 , 2311 , 4311
- volume with alps potentiometer and motor (like blue velevet)
- volume with R/2R resistor attenuator (R/2R ladder )
- volume with shunt type attenuator
- volume with TDA7318 etc.
I have only kit for R/2R type volume/attenuator and for alps motor potentiometer .
For the rest I have posted schematics , pcb , firmware and I will provide support .
If in the future will be more than 10 request I will provide more kit.
It will be help if you say what kit would you like !
Old 22nd November 2009, 06:32 PM   #30
danzup's Avatar
Hi
Perfect!
In the future firmware I will add this feature .
Need some free time for now !
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
