Yet another Volume controlers and source selections
Old 13th September 2010, 10:33 AM   #261
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by FarmTech View Post
Hey
If anyone like to use Dallas DS1267 dual pot I made a smal test code for bascom :
Thanks man !
It is good to gather all info and code about volume / selectors here with atmel /avr and bascom .
Keep on posting .
There are not better tube than 6P3S and 6N2P for my ears !
Old 13th September 2010, 11:18 AM   #262
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Default Another bargraph sample for lcd - bascom
Here is a sample of a bargraph stepping !!
Code:
'$sim
$regfile = "m16def.dat"                                     ' specify the used micro
$crystal = 8000000                                          ' used crystal frequency
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 20                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
Config Lcd = 16 * 2
Cursor Off
Deflcdchar 2 , 16 , 16 , 16 , 16 , 16 , 16 , 16 , 16        ' small
Deflcdchar 3 , 24 , 24 , 24 , 24 , 24 , 24 , 24 , 24        '
Deflcdchar 4 , 28 , 28 , 28 , 28 , 28 , 28 , 28 , 28        ' medium
Deflcdchar 5 , 30 , 30 , 30 , 30 , 30 , 30 , 30 , 30        '
Deflcdchar 6 , 31 , 31 , 31 , 31 , 31 , 31 , 31 , 31        ' Big
Declare Sub Warm_up                                         'the warm up tube sub
Dim Lcd_adr As Byte , Bar_tybe As Byte
Do
'test warm_up tube lcd 56 sec
Call Warm_up
Wait 1
Loop
End
Sub Warm_up
   Cls
   Locate 1 , 1                                             'Start at 1 chr on line 1
   Lcd "Preheating tubes"
   For Lcd_adr = 1 To 16                                    ' We have a 16 chr lcd or just use 16 chr bar
      For Bar_tybe = 2 To 6                                 'what type of bar to use
         Locate 2 , Lcd_adr                                 ' wher do we locate it on lcd
         Lcd Chr(bar_tybe)                                  ' put the chr on lcd
         Waitms 700                                         '16 * 5 * 700 =  56 seconds
      Next
   Next
   Cls
End Sub
/Kim
Old 14th September 2010, 09:57 PM   #263
FarmTech's Avatar
I made a TypO in the DS1267
Shift Send_volume , Left , 15
Correct shift is 16
Shift Send_volume , Left , 16
sorry for the mistake , this works also for DS1867
Old 17th September 2010, 11:39 PM   #264
FarmTech's Avatar
Default RC5 Remote - code change demo
Here is a sample code to add remote code/commands
to your program and store them in eeprom
Code:
' RC5 remote control code setup for Input selector audio amplifier
' Store new Remote buttons to eeprom and use them in program
' FarmTech 18.09.2010  DEMO to show how it works
'$sim
$crystal = 8000000
$hwstack = 32
$swstack = 20
$framesize = 40
Config Rc5 = Pind.3
Config Portb.0 = Input : Set Portb.0                        ' RESET BUTTON to enter a NEW remote if you change remote controler
Reset_button Alias Pinb.0
Config Lcdpin = Pin , Rs = Portb.2 , E = Portb.3 , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7
Config Lcd = 16 * 2
Cursor Off Noblink
Cls
Dim Address As Byte , Command As Byte                       'RC5 use
Dim Vol_u As Byte , Vol_d As Byte                           'new commnds var vol+ , vol-
Dim Shift_l As Byte , Shift_r As Byte , Power_1 As Byte     'new commnds var ch+ , ch- , power on/off
Dim My_address As Byte , Mut As Byte                        'new commnds var  new address , mute
'lcd constants for setup
Const Por = "PUSH POWER"
Const Chu = "PUSH CH +"
Const Chd = "PUSH CH -"
Const Volu = "PUSH VOL +"
Const Vold = "PUSH VOL -"
Const Mutonoff = "PUSH MUTE"
Declare Sub Get_remote                                      'sub get NEW RC COMMANDS
Declare Sub Test                                            'just a test  to see remote buttons working
If Reset_button = 0 Then Goto Setup                         'add new code for remote if portB.0 is low at startup (reset button)
Readeeprom Address , 2                                      'check if we have a remote programmed
If Address <> 255 Then                                      'code in eeprom no need to setup RC5 just read the code
  Readeeprom My_address , 2
  Waitms 25
  Readeeprom Power_1 , 4
  Waitms 25
  Readeeprom Shift_r , 5
  Waitms 25
  Readeeprom Shift_l , 8
  Waitms 25
  Readeeprom Vol_u , 10
  Waitms 25
  Readeeprom Vol_d , 12
  Waitms 25
  Readeeprom Mut , 14
  Waitms 500
   Gosub Test
Else
Setup:                                                      ' SETUP remote codes store them in eeprom Frist time use or reset via button at start up
   Locate 1 , 1
   Lcd "FIRST TIME USE"
   Locate 2 , 1
   Lcd "SETUP REMOTE NOW"
   Wait 3
   Cls
   Lcd "STEP 1 OF 6"
   Locate 2 , 1
   Lcd "PUSH A BUTTON"
   Do
      Getrc5(address , Command)
         If Command <> 255 Then
            Command = Command And &B01111111
         End If
      End If
   Loop Until Address <> 255
   My_address = Address
   Locate 1 , 1
   Lcd "OK FOUND REMOTE "
   Locate 2 , 1
   Lcd "PROGRAM BUTTONS "
   Wait 2
   Cls
   Locate 1 , 1
   Lcd Por
   Call Get_remote
   Power_1 = Command
   Wait 5
   Locate 1 , 1
   Lcd Chu
   Call Get_remote
   Shift_r = Command
   Wait 5
   Locate 1 , 1
   Lcd Chd
   Call Get_remote
   Shift_l = Command
   Wait 5
   Locate 1 , 1
   Lcd Volu
   Call Get_remote
   Vol_u = Command
   Wait 5
   Locate 1 , 1
   Lcd Vold
   Call Get_remote
   Vol_d = Command
   Wait 5
   Locate 1 , 1
   Lcd Mutonoff
   Call Get_remote
   Mut = Command
    Wait 5
   Cls
  Locate 1 , 1
  Lcd "READY TO USE"
  Locate 2 , 1
  Lcd "SAVE DATA   "
  Writeeeprom My_address , 2
  Waitms 25
  Writeeeprom Power_1 , 4
  Waitms 25
  Writeeeprom Shift_r , 5
  Waitms 25
  Writeeeprom Shift_l , 8
  Waitms 25
  Writeeeprom Vol_u , 10
  Waitms 25
  Writeeeprom Vol_d , 12
  Waitms 25
  Writeeeprom Mut , 14
  Wait 5
  Cls
 End If
Sub Test()                                                  'test program  here you add your normal code
Locate 1 , 1
Lcd "TRY REMOTE"
Do
      If Address = My_address Then
            Locate 2 , 1
            Select Case Command
            Case Power_1 : Lcd "POWER BUTTON    "
         Case Shift_r : Lcd "CH + BUTTON     "
         Case Shift_l : Lcd "CH - BUTTON     "
         Case Vol_u : Lcd "VOL + BUTTON    "
         Case Vol_d : Lcd "VOL - BUTTON    "
         Case Mut : Lcd "MUTE BUTTON     "
         Case Else
         Locate 2 , 1
         Lcd "UNKNOWN BUTTON  "
         End Select
         Waitms 500
         Lcd "                "
        End If
     End If
Loop
End Sub
Sub Get_remote()
 Do
      End If
   End If
 Locate 2 , 1
 Lcd "OK CMD IS " ; Command ; "  "
End Sub
End
Old 19th September 2010, 01:43 PM   #265
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
Default Sample code
Here is a sample code to add remote code/commands to your program and store them in eeprom
Hi
Your sample code didnt work for me until I added a couple of strings in your code.
See DarkOrange strings. Now it works
Its high time to add this feature to the firmware, but I think that there is not enough M8515 memory...
And one more thing: maybe we should use external EEPROM with 1.000.000 write cycles like AT24CXX or something like that.
Code:
'$sim
$regfile = "m8515.dat"                                      ' specify the used micro
$crystal = 16000000                                         ' external crystal 16MHz
$hwstack = 32
$swstack = 20
$framesize = 40
Config Rc5 = Pind.3
'Config Lcdpin = Pin , Rs = Portb.2 , E = Portb.3 , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcd = 20 * 2
Cursor Off Noblink
Cls
Enable Int0                                                 'we configure the INT0 interrupt to trigger when a falling edge is detected
Config Int0 = Falling
Enable Interrupts
  Waitms 25
  Waitms 25
  Waitms 25
  Waitms 25
  Waitms 25
  Waitms 25
  Readeeprom Mut , 14
  Waitms 500
   Gosub Test
Else
   Locate 1 , 1
   Locate 2 , 1
   Wait 3
   Cls
   Lcd "STEP 1 OF 6"
   Locate 2 , 1
   Lcd "PUSH A BUTTON"
   Do
   Disable Int0
Enable Interrupts
End If
Enable Int0
   Locate 1 , 1
   Locate 2 , 1
   Wait 2
   Cls
   Locate 1 , 1
   Lcd Por
   Call Get_remote
   Power_1 = Command
   Wait 5
   Locate 1 , 1
   Lcd Chu
   Call Get_remote
   Shift_r = Command
   Wait 5
   Locate 1 , 1
   Lcd Chd
   Call Get_remote
   Shift_l = Command
   Wait 5
   Locate 1 , 1
   Lcd Volu
   Call Get_remote
   Vol_u = Command
   Wait 5
   Locate 1 , 1
   Lcd Vold
   Call Get_remote
   Vol_d = Command
   Wait 5
   Locate 1 , 1
   Lcd Mutonoff
   Call Get_remote
   Mut = Command
    Wait 5
   Cls
  Locate 1 , 1
  Lcd "READY TO USE"
  Locate 2 , 1
  Lcd "SAVE DATA   "
  Waitms 25
  Waitms 25
  Waitms 25
  Waitms 25
  Waitms 25
  Waitms 25
  Wait 5
  Cls
 End If
Locate 1 , 1
Lcd "TRY REMOTE"
Do
            Locate 2 , 1
            Select Case Command
         Case Else
         Locate 2 , 1
         End Select
         Waitms 500
         Lcd "                "
        End If
     End If
Loop
End Sub
Sub Get_remote()
 Do
      End If
   End If
 Locate 2 , 1
End Sub
End
Old 19th September 2010, 01:51 PM   #266
FarmTech's Avatar
Hi ,
Oh Itook this out of my full program and forgot a few lines like the Enable Interrupts (sorry)
It was only tested in full code ,
Next is select TEXT for the INPUT selector
maybe like a string*8
this way we can setup new text to the select of input good idea ?
You can use the eeprom to store lots of data to free program space
like strings for input select text just use As Eram
sample :
Dim Menu_text(10) As Eram String * 15
Dim X As String * 15
Do
x = Menu_text(1)
x = Menu_text(2)
'ect
Loop
$eeprom
Data " CD " , " DVD " , " TUNER "
/Kim
Old 19th September 2010, 02:20 PM   #267
Pryanick's Avatar
Default eeprom
FarmTech thank you for code examples
Its great.
I added RC5 codes learning program into my firmware version. Now Im working on code adjustment.
Old 19th September 2010, 03:57 PM   #268
FarmTech's Avatar
Default Reduced Flash by 3%
I did a small test on Danzup´s lcd_m8515_v_1_5_ons.bas ´hope it ok´
orginal code : lcd_m8515_v_1_5_ons.bas
ROMIMAGE : 8EC hex -> Will fit into ROM
ROMIMAGE : 2284 dec
FLASH USED : 27 %
Use with Eram : lcd_m8515_v_1_5_ons.bas
ROMIMAGE : 7B6 hex -> Will fit into ROM
ROMIMAGE : 1974 dec
FLASH USED : 24 %
Romimage reduced by 310 dec , 3% less flash used NICE !!!
Code:
'only used 13 of the 30 strings in eeprom still have 17 left
Dim Menu_text(30) As Eram String * 16
Dim X As String * 16
'the command used to get them is :
'the old code was :  Lcd "Preamp controler"
'the new code  is :
X = Menu_text(10)    ' 10 is then "Preamp controler"
Lcd X
'ALL data MUST be 16 chrs long else you get errors in show
$eeprom
Data "DVD     selected" , "CD      selected" ' 1 2
Data "Tuner   selected" , "Tape    selected" ' 3 4
Data "Aux1    selected" , "Aux2    selected" ' 5 6
Data "Volume Down !   " , "                " ' 7 8
Data "Volume UP !     " , "Preamp controler" ' 9 10
Data "1.5.ons(c)danzup" , "  Power On !    " ' 11 12
Data "MUTE      !     "  ' 13
$Data
And we can change the data if we like
Code:
'old was Aux2    selected"
Menu_text(6) = "Aux9     selected" ' change to
Thats simple
Old 19th September 2010, 08:14 PM   #269
FarmTech's Avatar
Default EDIT Input Select Text
Here is a test code to edit your Input Select Text
just a test code can be better but 4now its ok
It use As Eram for more free flash space
Enjoy
/Kim
Code:
' EDIT Input Select TEXT DEMO
' BUTTONS :
' In Normal Mode
' PortA.0 = Select Input - show on lcd as normal program steps 1 2 3 4 5 6 1 2 ect ..
' PortA.1 = Enter EDIT Input Select Text
' In EDIT Mode
' Porta.5 = Select what Input select Text to EDIT steps 1 2 3 4 5 6 1 2  ect
' PortA.2 = select char for test steps A B C D E F G  ect Incr chr like UP
' PortA.3 = select char for test steps G F E D C B A  ect Decr chr  like Down
' PortA.4 = Use the selectet char and goto next char you MUST ENTER ALL 16 chars in this test
' It jump to Normal Mode when done '(or next if you edit the code under If Pina.3 = 1)
' PortA.6 = EXIT Edit Mode and goto normal mode
' FarmTech 19.08.2010
'$sim
$hwstack = 32
$swstack = 20
$framesize = 40
Ddra = &B00000000                                           ' PA0...PA7 are input
Cursor Off
Config Lcd = 16 * 2
'put 6 labels into eeprom
'$eepromhex  enable if you like bascom to make a *.EEP ( eeprom file )
'then you can delete the next 5 lines this in bas  and just use the *.eep when you program avr
$eeprom
$data
Dim Menu_text(6) As Eram String * 16                        'only used 6 for ths test
Dim Inp_sel As Byte
Declare Sub Af_sel
Declare Sub Edit_text
Cls
Enable Interrupts
Inp_sel = 2
Call Af_sel
Do
 'test the input select 1 - 6
 If Pina.0 = 1 Then
 Incr Inp_sel
 If Inp_sel > 6 Then Inp_sel = 1
   Call Af_sel
 End If
 'enter set up
 If Pina.1 = 1 Then
   Bitwait Pina.1 , Reset
   Call Edit_text
 End If
Loop
End
'-----------EDIR INPUT TEXT-------------------
Sub Edit_text:
Local My_chr As Byte
Local X_chr As Byte
Local Menu_point As Byte
Local My_string As String * 16
Local Old_select As Byte
Old_select = Inp_sel
My_chr = 65
X_chr = 1
Menu_point = 1
My_string = ""
Locate 1 , 1
X = Menu_text(menu_point)
Lcd X
Cursor On Blink
Locate 2 , 1
Lcd Chr(my_chr)
Do
If Pina.2 = 1 Then                                          'UP select the chr you like to use
   Incr My_chr
   If My_chr = 33 Then My_chr = 48
   If My_chr > 90 Then My_chr = 32
   Locate 2 , X_chr
   Lcd Chr(my_chr)
   Waitms 80
   Cursor On Blink
End If
If Pina.3 = 1 Then                                          'Down select the chr you like to use
   Decr My_chr
   If My_chr = 47 Then My_chr = 32
   If My_chr < 32 Then My_chr = 90
   Locate 2 , X_chr
   Lcd Chr(my_chr)
   Waitms 80
   Cursor On Blink
End If
If Pina.4 = 1 Then
   My_string = My_string + Chr(my_chr)                      ' add the chr to the string jump to next 1 to 16
   'Waitms 200
   Bitwait Pina.3 , Reset
   Incr X_chr
   My_chr = 65
   Locate 2 , X_chr
   Lcd Chr(my_chr)
   Cursor On Blink
   If X_chr = 17 Then
      Menu_text(menu_point) = My_string
      Waitms 25
     ' Incr Menu_point
     ' If Menu_point > 6 Then
         Exit Do
      Else
      Cls
         Locate 1 , 1
         Lcd X
         My_string = ""
         X_chr = 1
         My_chr = 65
         Locate 2 , 1
         Lcd Chr(my_chr)
         Cursor On Blink
      End If
   End If
End If
If Pina.5 = 1 Then
   Incr Menu_point
   If Menu_point > 6 Then Menu_point = 1
   Cls
   Locate 1 , 1
   Locate 1 , 1
   Lcd X
   My_string = ""
   X_chr = 1
   My_chr = 65
   Locate 2 , 1
   Lcd  Chr(my_chr)
   Cursor On Blink
   Bitwait Pina.5 , Reset
End If
If Pina.6 = 1 Then Exit Do
Loop
Cls
Lcd "EXIT setup"
Waitms 25
My_string = ""
Inp_sel = Old_select
Call Af_sel
Waitms 50
End Sub
'------Af_sel---------------------------
Sub Af_sel:
Home Upper
If Inp_sel = 1 Then
X = Menu_text(1)
Lcd X
End If
If Inp_sel = 2 Then
X = Menu_text(2)
Lcd X
End If
If Inp_sel = 4 Then
X = Menu_text(3)
Lcd X
End If
If Inp_sel = 8 Then
X = Menu_text(4)
Lcd X
End If
If Inp_sel = 16 Then
X = Menu_text(5)
Lcd X
End If
If Inp_sel = 32 Then
X = Menu_text(6)
Lcd X
End If
End Sub
@Edit forgot to add the UP/Down button , (Input Select Text) a long string of chars
Old 19th September 2010, 09:16 PM   #270
FarmTech's Avatar
Default Bug fix EDIT Input Select Text
Bug fix
Cursor was not set in first version
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
