Yet another Volume controlers and source selections
Old 19th June 2010, 10:17 PM   #231
TBKK is offline TBKK  Germany
danzup,
nice job, i want to build the one with LED.
I see only the sources for the LCD not for the LED
or can I use the same BAS files for both.
How do you indicatie the input source on the LED?
does it work in every RC5 remote control?
I have an tube preamplifier with a potentiometer of 22k, can I use this design?
I take 60 sec. to warm up the tubes is it possible to change that?
I prefer the Matrix displays is this also possible?
Old 20th June 2010, 04:33 AM   #232
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by TBKK View Post
danzup,
Here are the bin and hex for LED . The .bas files are not in archive .
You must try the ir remote to find the one that work with controller .
When you press the menu button the LED display flash and display from 1 to 4 input then after 30 secs flash again and change automatically to display volume again .
Firmware for tube is different that that for SS so this firmware must be used only for tube variant.
I do not have a matrix variant .
There are not better tube than 6P3S and 6N2P for my ears !
Old 20th June 2010, 07:39 PM   #233
danzup,
can you explane what happen on the display does it count 60 sec back or what?
the remote control voor LCD is easier according to the post is it difficult to build this also for the LED? I have two remote control of Philips that mean i must have more?
because LED is very simple how can you see witch input you have select?
Old 21st June 2010, 03:52 AM   #234
danzup's Avatar
When you press the menu button the LED display flash and display from 1 to 4 the input selected then after 30 secs flash again and change automatically to display volume again .
Yes it is counting from 70 sec down after power on to wait for tube to heating .
Old 22nd June 2010, 09:06 AM   #235
didiet78 is offline didiet78  Indonesia
For remote control, i build based on App Notes #105 from MCS Electronics AN #105 - Sending RC5 and SONY IR codes - MCS Electronics,
with just change RC5 System Address and RC5 Command.
Old 22nd June 2010, 09:10 AM   #236
danzup's Avatar
Perfect done !
Also , I have used that piece of software for Sony IR codes and work perfectly.
For those who want to use Sony instead RC5 /Philips .
Old 23rd June 2010, 04:20 AM   #237
This my remote full view
And this component view no smd
Old 9th July 2010, 10:08 AM   #238
Jempie is offline Jempie  Indonesia
Hi Danzup,
Thanks for all, work perfect, do you have the volume Bar for the PGA2310 software
Jempie
Old 9th July 2010, 12:37 PM   #239
danzup's Avatar
Originally Posted by Jempie View Post
Hi Danzup,
Jempie
Hi Jempie , no .
I do not have such firmware.
If I will have some time in future I will write .
Best regards.
Dan
Old 31st August 2010, 08:47 PM   #240
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
Default Bar Graph
Hi
Here is my bar graph version
Dim I As Word
Dim Cols As Word
Deflcdchar 0 , 32 , 32 , 32 , 27 , 27 , 32 , 32 , 32 ' empty symbol
Deflcdchar 1 , 32 , 32 , 31 , 31 , 31 , 31 , 32 , 32 ' filled symbol
Declare Sub Bargraph
'-----Bar graph------
Sub Bargraph:
Cols = L / 17
Locate 1 , 1
For I = 1 To Cols
Lcd Chr(1)
Next I
For I = Cols To 14
Lcd Chr(0)
Next I
End Sub
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
