Yet another Volume controlers and source selections
Old 9th June 2010, 06:40 AM   #211
KnightofAwesome is offline KnightofAwesome  Canada
KnightofAwesome's Avatar
Default Started putting parts in, pictures soon
I have a quick question,
I'm currently building carlos's blame ST along with this VCSS. I've discovered that each channel pulls 180watt's and 2.5 amps (I am currently building 2 channels) . This part of the schematic here:
What kind of resistor wattage ratings would i need for R14 and R15? And if there's any information i need to know, let me know.
Thanks,
Kurtis
Old 9th June 2010, 06:49 AM   #212
danzup is offline danzup  Romania
danzup's Avatar
Thanks,
Kurtis
1/2W ( that resistors do not depend on the power of consumer side but there are on circuit together with capacitors to protect the relay contact ) .
Voltage of capacitor >120V I think you know that .
the correct schematics :
There are not better tube than 6P3S and 6N2P for my ears !
Old 12th June 2010, 08:56 PM   #213
Jempie is offline Jempie  Indonesia
Dear Danzup,
does your design works also with VFD display's ?
try to build your design but use an VFD display of Futaba
Old 13th June 2010, 10:11 AM   #214
Dear Danzup,
I want to learn what you do with the source (BAS files) do you have links
witch editor and compliler i can use to change the BAS source
Old 14th June 2010, 06:15 AM   #215
danzup's Avatar
Originally Posted by Jempie View Post
Dear Danzup,
1.
2.
1.YES !
It is working very well !
2. BASCOM :
download for free here :
Downloads - MCS Electronics
Old 15th June 2010, 08:18 AM   #216
Dear Danzup,
could you also inform me witch remote control can be used
in your project with the PGA
Old 15th June 2010, 09:11 AM   #217
danzup's Avatar
Dear Danzup,
With all my project : all RC5 Philips coded IR remote will work.
Use a universal remote and do a scan on remote till the controller respond to on/off button then that is .
For those that used ever a universal remote know what I am saying here .
Or press from universal remote unit the button : " cable/sat ".
Vol+ ,Vol - ,Ch+ ,Ch- ,power and mute ( for some project pressing buttons 1 to 4 will direct select input 1...4 ).
Do not use remote from : Sony , Technics, Mitsubishi and another japan type as there is known they do not implement RC5 Philips type of encoding .
( Even an Orion tv set ir remote work for me ( !! ) )
look here :
http://i35.tinypic.com/flvm7c.jpg
Old 15th June 2010, 02:58 PM   #218
Danzup,
i can not find the complete file bas and HEX for the project 2 with PGA
thanks
Old 15th June 2010, 03:21 PM   #219
danzup's Avatar
Danzup,
thanks
page 2 post #18 - variant with stop at +10dB
page 3 post #25 - variant with stop at +31.5dB
a little reading of thread will reveal you the files but there are not the .hex attached in post#18 and after you install Bascom you must compile this code and then write to Atmel UC .
I will provide the complete files for people who only want to program the Atmel chip with firmware in post #18 without installing Bascom compiler .
In the post #25 there are all files included the .hex in .zip archive .
Old 15th June 2010, 03:32 PM   #220
dear Danzup,
could you send me the direct for the compiler. I have the Genius G540 programmer
does this work..
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
Copyright ©1999-2017 diyAudio
