Yet another Volume controlers and source selections
Old 12th September 2009, 07:59 AM   #11
danzup is offline danzup  Romania
danzup's Avatar
And some pictures with the variant with atmega8515 and alps motor potentiometer build by alex_mm :
http://i26.tinypic.com/9j39dz.jpg
Old 15th September 2009, 07:15 AM   #12
danzup's Avatar
"Hello Danzup,
I would like to ask a question and I hope I'm not OT cause I've been OT in the "Ebay Hdam module" thread.
Does your relay based ATT suffer from audible click in the speaker ( not the relay) ?
Cause I have a similar ATT I bought off ebay, And It has audible on the speaker click at only 2 points in its attenuation range. "
I give here the answer : no there are not such click or pop in speakers in my resistor r2r or shunt type volume .
Because everything is done properly in soft and in pcb layout of the volume controller .
Every up or down in volume attenuation is done in software by switching to max attenuation (mute ) for 2.... 6 ms (depending on the relay parameters !!! every type of relay have different time for settle ) and then applying the new value .
Ok ?
Old 15th September 2009, 07:19 AM   #13
danzup's Avatar
A little history about all my realizations in volume controllers :
http://translate.google.ro/translate...state0=&swap=1
Old 15th September 2009, 04:15 PM   #14
marchel is offline marchel
Originally Posted by danzup View Post
"Hello Danzup,
Ok ?
First of all, thank you , and I want to apologize if I make a stupid question.
This is the stupid question: So you mean to say that your ATT will momentarily mute in between relay transition?
Old 16th September 2009, 06:07 AM   #15
danzup's Avatar
Yes !
This is what i have explained to you !
And if your kit purchased from e-bay is with atmel atmega I will write for you a new software if you give me the schematics .
Old 16th September 2009, 09:26 AM   #16
Yes !
Thanks , I greatly appreciate your kindness, But I dont think my att is programable.
Thanks.
Old 25th September 2009, 01:17 PM   #17
danzup's Avatar
And another type of volume/selection controller made by me in 2005 .
Who want the soft just ask .
Used I2C port expander from Philips to command the relay PCF8574A .
There are not better tube than 6P3S and 6N2P for my ears !
Old 18th November 2009, 01:55 PM   #18
danzup's Avatar
Default soft for Pga 2310 Pga 2311 Pga4311 with 6 inputs and encoder
@Pryanick
soft for Pga 2310 Pga 2311 Pga4311 with 6 inputs and with dB attenuation on LCD
(the schematics are from Project nr. 2 )
Old 18th November 2009, 02:07 PM   #19
Pryanick is offline Pryanick  Belarus
Pryanick's Avatar
Send a message via ICQ to Pryanick
Thank you danzup
I'll test it today in the evening
Old 19th November 2009, 03:03 PM   #20
Pryanick's Avatar
Default +31.5db max
Hi
I tested firmware today
One question I've got: why only +10db?
Datasheet says that +31.5db max should be.
Danzup, can you fix it please?
Thank you.
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
