| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#911 | |
![]() http://scitation.aip.org/getabs/serv...03001594000001 |
#912 |
#914 |
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#915 |
You guys amaze me. However, I am right on this, just wait and see. However, I don't have the time or energy to redo everything and spoon feed those who don't want to change their paradigm.
My job in life is making better audio products. I already know how to do so, without 'proving' it to anyone. It is just NOW that we have separate PIM measurements for IC's by one associate of mine, and a more complete understanding of the magnitude and position of PIM compared to TIM, by Mitch Cotter. I am giving the ANSWER to successful audio design from MY perspective and understanding. Many here may have a separate opinion, but you better be right, if you want to compete with the 'Big Boys' like Charles, Nelson, or me, all 'Engineering Technicians' by Anatech's personal definition. We may choose to disagree on this,as well, but so what? Last edited by john curl; 3rd September 2009 at 07:38 PM. |
#916 |
#918 |
#920 | |
First, I am very reluctant to compare distortions created by speakers with distortion created by electronics. That a loudspeaker may create several percent distortion of whatever kind should not make us complacent about a solid state amplifier that creates 0.1% distortion. I'm comfortable thinking of them as two completely different things. Similarly, I'm at peace with the situation where a vacuum tube amplifier with 0.5% measured distortion sounds better than a solid state amplifier with 0.1% distortion. This doesn't mean we throw the baby out with the bathwater and completely dismiss distortion measurements, especially ones that are sensitive to crossover distortion and 7th harmonic level, for example. Second, I totally agree that "unnatural" distortions may be much more audible than the more normal distortions. John asserted that PIM produces much more relatively audible "unnatural" (non N/M) distortions than other distortion mechanisms. If PIM really does produce such types of "unnatural" distortions, then we have to look much more closely at PIM. Perhaps we then need to set a criteria for such distortions as needing to be, perhaps, 10 or 20 dB lower than would otherwise concern us. This issue is not where I disagree with John on PIM. My concern is twofold. First, it is very unclear how PIM can create such in-harmonic distortions under any reasonable conditions at any reasonable levels. Secondly, if a lab experiment exposes such in-harmonic distortions, how does one conclude that they are a result of the PIM mechanism as opposed to something else? Cheers, Bob |
