Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th August 2009, 11:11 PM   #761
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally posted by RocketScientist
So I agree it's all about keeping perspective and the big "macro" goals in mind. It's all too easy to spend too much time worrying about things that are unrealistic or simply don't matter in practice.
...like THD+N numbers. Well said!
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 12th August 2009, 11:45 PM   #762
anatech is offline anatech  Canada
anatech's Avatar
Hi John,
I've said similar things in the past myself. I do agree, but understand that I do not manufacture anything. I service and most of the things I find out are loosely related to what I may read and 100% based on what I see happen in the physical world. Besides, I have a reputation for that kind of work.
In fact, a 1% match between the compliments in a complimentary differential pair represents a lot of work. I don't usually get them that close, but certainly much closer than the production line delivers them. To say I was 1% or closer on pairs and probably around 5% on the compliments might be fair. I do know from experimenting that a closer match does a couple things for the design. It makes the bias current a little more stable (many depend on the current in the diff pair), and it does make the DC offset both lower and more stable. Take an amp with 60 mV DC offset that drifts and turn out one with less than 5 mV that is stable. No more clicks and pops and it will both sound a little better (not dramatically as I would describe it, some feel that way) and measure slightly better. The sound quality difference is greater than a total distortion number might suggest.
There are amplifiers that this effort is wasted on, so I don't waste my time or the customer's money on those. Everything in balance.
This might also be reflected in your efforts to reduce the seventh order distortion if you optimized everything about that issue. Wire types and connections could be construed that way as well. My experience comes from years working on other designs and also prototypes and experiments. I follow those things that actually do make a difference that can be heard by several different people in different rooms and systems. Something I can measure repeatedly also counts for a real change, could be good or bad. Either way, it's noted.
I think we are on the same page there John. We are saying the same thing.
I wonder. John, have you ever tried a super close match to see if there is any effect on the seventh harmonic? Given that this work is done in the error detector / amplifier of an amplifier, is it worth one experiment on your own? Yes, I do know we are mostly looking at even harmonics and that odd harmonics may be affected more in the Vas / current sources / or output stages, but one never knows until the numbers come in. BTW, numbers are only a way to measure or quantify a performance change. They are valid when taken along with the rest of the data and information. Otherwise, none of us would have any sort of distortion measuring apparatus (including spectrum analyzers or wave meters).
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 13th August 2009, 12:12 AM   #763
Wavebourn's Avatar
Originally posted by anatech
Hi Anatoliy,
Yes, of course they can. I don't see On-Semi doing this, not for these parts. From what I understand, they improved their processes. That, I will believe.
No one is going to reject that much silicon and charge so little for the end product.
Hi Chris;
did not you see color coded and letter coded devices already?
We had such a process back in 1970'th in Russia: the same devices were automatically measured and sorted out right on conveyor, before their automated labeling. However, sometimes production people used to pour some very good devices to the bin with worse ones, because there was a State Plan, to produce certain amounts of devices with particular letter codes. That's why, knowing how the manufacturing works in reality, I often used a characteriograph to find real jewels among almost rejects. Such a way I got many matched pairs of 60W complementary transistors with equal betas close to 200 and breakdown voltages more than 150V, from a batch with Beta > 25 and Vcb <50.
Selecting matching pairs such a way don't mean rejecting other devices. Single device does not mean unhappy one, like in case of human beings.
Old 21st August 2009, 05:26 PM   #764
What's next now that the site is back up?
Old 21st August 2009, 05:48 PM   #765
bogdan_borko's Avatar
Come on John, we`re waiting.
Old 21st August 2009, 07:46 PM   #766
PMA is offline PMA  Europe
PMA's Avatar
New server engine vs. Mac problem, I would guess.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 21st August 2009, 07:53 PM   #767
KSTR is offline KSTR  Germany
KSTR's Avatar
http://www.diyhifi.org/forums/viewto...p=40359#p40359
Hhm, looks like he's tied up with something great to come...
Old 21st August 2009, 07:56 PM   #768
PMA's Avatar
A week ago .....
Old 21st August 2009, 08:21 PM   #769
syn08 is offline syn08  Canada
Originally Posted by KSTR View Post
http://www.diyhifi.org/forums/viewto...p=40359#p40359Hhm, looks like he's tied up with something great to come...
The only surprise is JC getting into such (otherwise, it was done 20 years ago). I wonder what the (hobbyst and professional) purists will comment about. And of course, I can't wait to read a M. Fremer rave review. The same guy that was complaining about the digital circuitry (MCU, remote, etc...) in a preamp, as deeply impacting the sound.
Old 21st August 2009, 08:26 PM   #770
PMA's Avatar
Commercial pressure? (class D)
Currently Active Users Viewing This Thread: 10 (3 members and 7 guests)
Jonathan Bright, bmcevers
Page generated in 0.26836 seconds (63.16% PHP - 36.84% MySQL) with 11 queries
