| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#531 |
Thermal transient effects
Try multitone signal 50+51Hz (beat 1Hz) with 0dB and 10k+11k with -10-20dB relative to 50+51Hz. Observe only IMD products 10k+11kHz(1kHz...), When driving amp with this signal just under limit, power is cycling from 0-100% with 1Hz, so IMD products cycling should be visible..You can try e.g 50+50,2 Hz as "base", so thermal cycling is with 5sec period. |
#532 | |
Demian Martin Product Design Services |
#533 | |
#534 |
Have the signal, but see nothing special in a FFT.
#535 | |
#536 |
This would depend on a circuit used. BTW, the test signal is periodic ....
#537 |
Hmmm.... I have some quartz resonators about 7 KHz and pair of 500 Hz 60 db/Oct filters. I'll see what differences in frequencies of that crystals I have.
One double triode with JFets in cathodes would make nice clean 2-tone oscillator.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#538 | |
2012, our time is running out. |
#539 | |
BTW, you should use no averaging and FFT e.g. 4096 or 8192. With underbiased amp i can see so with sugested signal sidebands "pumping" at levels between -120 to -110dB , peaks 10+11kHz at -20dB, 50Hz components peks at -6dB on spectra. Power is cycled from 1W to 100W..But is it from termal effects? Sure not. |
#540 | |
Start out with two oscillators, a very stable low distortion low frequency oscillator and a modulatable high frequency oscillator. Run the lf oscillator a low level through the chain into a sensitive phase meter. Mix into the input the HF oscillator pushing the system to close to its power limits. Cycle the HF oscillator at various rates consistent with the thermal time constants in question. Pass the output through the LPF and see the effect on the phase meter comparing the input phase to the output phase. I have read but can't cite references that the relative phase of a composite signal are not audible, however if the phase relationship is changed the change is audible. I don't know if there is any data on this.
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| FrankWW, bmcevers |
| Page generated in 15.34568 seconds (0.88% PHP - 99.12% MySQL) with 11 queries |
