Go Back   Home > Forums > Source & Line > Analog Line Level
Old 27th July 2009, 04:14 PM   #521
Power amps have thicker substrates.
Old 27th July 2009, 05:49 PM   #522
kamskoma's Avatar
Default Aluminium works
Nelson Pass,
Once you recommended an "how to" book about working with aluminium, do you remember the author and title of this book!
This book can be very useful for preamp DIY builders.
Kamskoma
Generatore di Segnali Sinusoidali
Old 27th July 2009, 05:50 PM   #523
Originally posted by 1audio
How does the transient thermal change affect the signal passing through the amp? This is clearly not easy to measure with steady state tests and it may be significant. I have been reading about delay vs. temperature in very precision systems and the numbers are in the 10 pS/degree C in a carefully compensated system. I seriously doubt anyone would hear something that small as a steady state change but an abrupt change could modulate a signal enough to be audible (if we knew what was audible).
I worry the most about transient under-bias of a class AB output stage. If I have to pick my poison, I'll always go with overbias and some possible gm-doubling consequences.
Bob
Old 27th July 2009, 05:59 PM   #524
Originally posted by KSTR
Sounds like a good idea. Something like measuring small signal HF Zout during/after a power burst, by backdriving the amp with a LF current. Maybe in a high (noise) gain config to make it more readily apparent.
- Klaus
This is a good idea. A variant would be to operate the amplifier at 20 kHz at the power level that nominally yields the highest amount of crossover distortion. Then back-drive the amplifier with a low frequency at moderate power at perhaps 10 Hz. Then look at the 10 Hz modulation of the 20 kHz distortion residual on a scope. Note that the high damping factor of the amplifier under test keeps most of the low-frequency back-drive signal out of the distortion analyzer.
Bob
Old 27th July 2009, 06:47 PM   #525
PMA is offline PMA  Europe
PMA's Avatar
Bob
Good point again. No we can discuss a measure of overbias, with respect to mentioned thermal transients as well. And soft transition.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 27th July 2009, 11:21 PM   #526
The one and only
Nelson Pass's Avatar
Default Re: Aluminium works
Originally posted by kamskoma
Nelson Pass,
Did I? Hmmmm...
Old 27th July 2009, 11:25 PM   #527
SY's Avatar
Nelson Pass,
Kamskoma
Though tube-centric, "Building Valve Amplifiers" is a very good guide to general metal-bashing for audio.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 28th July 2009, 08:44 AM   #528
h_a is offline h_a  Europe
h_a's Avatar
Well, maybe I'm missing something here, but thermal effects on THD should be quite easily investigated.
Just run a 2 tone test into the DUT, say 1kHz plus a 40kHz sine. Apply bandpass to get rid of the 40kHz. Estimate from standard 1kHz THD the additional intermodulation products and subtract. Certainly a little matlab or similar is usefull for better precision.
Have fun, Hannes
EDIT: or mount transistors on high power Peltier-elements.
Old 28th July 2009, 08:45 AM   #529
kamskoma's Avatar
Default Heavy Metal Works
Yes, I will remember it was a Harley Davidson related book, or at least motorcycle metal works.
Kamskoma
Old 28th July 2009, 08:46 AM   #530
h_a's Avatar
The art of motorcycle maintenance?
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
FrankWW, bmcevers
Page generated in 0.22707 seconds (57.94% PHP - 42.06% MySQL) with 11 queries
