Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th July 2010, 07:18 PM   #4951
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by SY View Post
Quantization distortion is very, very well known. That's why we use dither and the anti-imaging filter.
Yes, but we only get "smoother" sound. Resolution remains the same or is LOWERED.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 20th July 2010, 07:29 PM   #4952
SY's Avatar
PMA: That does not turn out to be the case. Please read the extensive sets of papers by Lipshitz on this subject:
J. Vanderkooy and S.P. Lipshitz. 1987. Dither in digital audio. J. Audio Eng. Soc. 35, 966-975.
J. Vanderkooy and S.P. Lipshitz. 1989. Digital dither: Signal processing with resolution far below the least significant bit. Proc. AES 7th International Conference "Audio in Digital Times", Toronto, Canada, May 14-17, 1989.
S.P. Lipshitz, J. Vanderkooy and R.A. Wannamaker. 1991. Minimally audible noise shaping. J. Audio Eng. Soc. 39, 836-852.
S.P. Lipshitz, R.A. Wannamaker and J. Vanderkooy. 1992. Quantization and dither: A theoretical survey. J. Audio Eng. Soc. 40, 355-375.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 20th July 2010, 07:37 PM   #4953
PMA's Avatar
SY, thank you very much. I know the papers on dither, and different dithering methods as well. No dither would give you more than 16bits resolution from 16bits quantization. What you get is randomizing of quantization error, and change in SFDR. We are not here to repeat such basics.
Old 20th July 2010, 07:38 PM   #4954
Joachim Gerhard's Avatar
When i record my little band, i use double speed DSD. When i downconvert to 16/44 and listen to the CD i burned, i can interstingly hear the biggest diffences in the bass. It sounds less warm and musical. Well, we do not have a drummer, it´s more guitar, bass and vocals and some beats from the drum computer so my material is not particular rich in treble transients.
Old 20th July 2010, 07:40 PM   #4955
SY's Avatar
Then you're using a nonstandard definition of "resolution," especially in the context of your response to myrrh. Please give me yours.
Old 20th July 2010, 07:45 PM   #4956
PMA's Avatar
Okay, I should have said "no new information". Interleaved computed samples do not bring new information. But interleaved samples are a product of oversampling, not the dither. Dither in fact masks last +/-0.5LSB or +/-1LSB.
Old 20th July 2010, 07:48 PM   #4957
SY's Avatar
Please define "masks" in the context you're using it. Does the -60dB noise of a phono stage "mask" information? The -70-80dB of tape noise?
BTW, here's a nice layman's explanation of the relationship between dither and resolution:
Daqarta - Dither: Noise + Averaging = Resolution
Old 20th July 2010, 07:54 PM   #4958
SY's Avatar
Stereophile: Bryston BDA-1 D/A converter
I'd call your attention to Figure 3 and Figure 6.
Old 20th July 2010, 08:01 PM   #4959
scott wurcer's Avatar
In a properly band limited system there is no new information to get. The interpolated samples are exact within aperature and amplitude error. Your use of "mask" is unclear here.
2012, our time is running out.
Old 20th July 2010, 08:03 PM   #4960
PMA's Avatar
Tape or vinyl is not the case now. We are speaking about dither and resolution. For 16 bits, 1LSB = 1/65536 of Full Scale Range. This is a Resolution of 16 bit quantization. No dithering method is able to increase it.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
FrankWW, bmcevers
Page generated in 0.22015 seconds (57.01% PHP - 42.99% MySQL) with 11 queries
