| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#401 |
Phase shift itself when reactivity is driven does not create distortions; what does, non-linear output impedance of the thingy that drives.
Speaking of measurements, what may be observed, a phase angle between input and output signals. For better visibility the load may be plain resistive. And again, let me repeat myself: single-ended phase inter-modulation may be inaudible, when it mimics Doppler effect. Otherwise it sounds nasty. Long time ago I thought that it may be used for guitar effects. Nope! It sounds nasty when is non-linear and significant; I tried it with bass guitar thinking of aggressive sound. Gave up.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#402 |
IMO you will measure nothing important by this method in a standard good circuit.
#403 | |
2012, our time is running out. |
#404 |
I liked the AD844 very much.
#405 |
Tom, get the open loop bandiwith to 20KHz and THEN we can talk.
#406 |
Pretty easy on the AD844 the pin is there to cripple the VAS for any OLBW you want. I talked with Mitch for almost an hour and he's not telling much. I still think this stuff is a red herring but I'm not going to argue about it anymore.
#407 |
Pin 5.
#408 | |
Non é mai abbastanza... |
#409 |
Yes, almost. But the AD844, e.g., is more than 10x faster, regarding SR, and it counts. OLG is quite same, but the AD844 is CFA, and it must be considered.
#410 | |
Also, the AD844 can be used open loop with excellent audio performance, howzzat for audio nirvana You can set the gain by the ratio of two resistors (to pin 2 and pin 5). jd
/Another new issue: Linear Audio Volume 3! |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| bmcevers |
| Page generated in 0.22719 seconds (60.30% PHP - 39.70% MySQL) with 11 queries |
