Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th April 2010, 02:37 AM   #4051
Phono stage.
Old 7th April 2010, 05:01 PM   #4052
Any more resistor questions, anyone? Or resistor measurement results. I have certainly been pleasantly surprised by the measured results.
Old 8th April 2010, 01:20 AM   #4053
Joachim Gerhard's Avatar
i got resistors from Simon and they look very familiar to me. Quite big though.
I will listen, not measure if that is ok. I will use the latest version of my High Z MPP plus the Inductive RIAA. I have the resistors on Eichmann plugs so swapping is easy.
I will also get some Texas Components Naked Z Foils with the same values so a lot of work is before me. Sofar i got the best sound with 300 Ohm old military wirewound Dales. They sounded even better then the 1Kohm Naked Z Foil i have. The Z Foil where more detailed but the Dale had a more fleshed out sound i liked better.
They where not the same value though, so i will do that experiment again with the same values but different types.
Old 8th April 2010, 03:34 PM   #4054
Does anyone know of a QUALITY resistor like the naked Vishay, but significantly cheaper? I can't use naked Vishay's everywhere.
Old 8th April 2010, 07:10 PM   #4055
Let us see what Jocko has to say. The samples I sent him measure better and cost much less.
I expect there to be certain differences, but I will not say what they are so as not to influence his opinion.
Old 8th April 2010, 07:16 PM   #4056
PMA is offline PMA  Europe
PMA's Avatar
I am using Vishay MBB 0207 resistors now, as a rule.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 8th April 2010, 10:46 PM   #4057
Here is latest information fron Vishay. Quite compete.
Listening to all this may need 10 years at last and i thought that i am a freak.
The real freaks are at Vishay.
I like the oil filled zerro temkcos just by looking at them.
http://www.vishay.com/docs/49789/vmn-pl03.pdf
Old 8th April 2010, 10:50 PM   #4058
Here are PMA“s :
http://www.vishay.com/docs/28768/mbsmavg6.pdf
Old 8th April 2010, 11:07 PM   #4059
Thanks, both of you.
Old 9th April 2010, 03:04 AM   #4060
Well, I guess we should try to go forward. I am glad that several of you have learned more about resistors than you previously thought measurable or possible. Why it should matter is something that we can only guess at. I hope that we can find something else to discuss that will not create too much concern or confusion.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
bmcevers
Page generated in 0.23934 seconds (60.30% PHP - 39.70% MySQL) with 11 queries
