Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd February 2013, 07:22 PM   #34121
Esperado's Avatar
32 bits with dithering seems satisfactory, on a theoretical
point of view ?
Christophe.
Ultimate Protection
Old 3rd February 2013, 07:27 PM   #34122
PMA is offline PMA  Europe
PMA's Avatar
Real world would be no better than 20 bits.
Old 3rd February 2013, 07:43 PM   #34123
Esperado's Avatar
Yes, let say 24+ 8bits (60db) of volume control = 32.
Christophe.
Ultimate Protection
Old 3rd February 2013, 07:50 PM   #34124
1audio is online now 1audio  United States
A good digital volume implementation is not simple and then it needs to have the post ADC gain optimized to ensure you are not running at too much attenuation on the digital side. Dithering the attenuated output is important.
In a system environment it can be a good solution but with individual components will run a high risk of getting the gain structure non optimal. The Berkeley Alpha dac is a good volume implementation but really needs a separate preamp on the output to get the gains aligned in many cases.
Demian Martin
Product Design Services
Old 3rd February 2013, 08:23 PM   #34125
BV is offline BV  Slovakia
Sorry, but this is IMO very "suboptimal" solution.
Old 3rd February 2013, 08:46 PM   #34126
Esperado's Avatar
Oh, really ?
Christophe.
Ultimate Protection
Old 3rd February 2013, 09:11 PM   #34127
Max Headroom's Avatar
Location: West Australia, straight over the road from the beach, natural ambient sounds only.
Default Leaky Coupling Caps...
Originally Posted by john curl View Post
Depends on the cap quality Gootee.
Yes.
I have replaced many leaky pot and switch electrolytic coupling caps.
The symptoms are a scratching noise when the pot is moved, and a thump or scratching when switches are operated or rocked.
Dan.
Old 3rd February 2013, 09:12 PM   #34128
fas42 is offline fas42  Australia
Originally Posted by Esperado View Post
As i use mainly Digital sources, my next solution for volume control will be exclusively in the digital domain. And i will add a ADC to deal with my analog sources.
JC will kill-me
Good move ... you won't be sorry, Christophe. My first CD player was the top Yamaha of the time, used an analogue volume out. Gave me hints of what was possible, but then started playing up, tracking problems. Dealer exchanged for the new model top unit, which used digital volume. This is when I started making real progress, and the breakthrough occurred ...
Frank
Old 3rd February 2013, 09:20 PM   #34129
Why? If totally in digital it works like charm, my still working 27 year old Yamaha beats the pants off nearly all digital plus analogue I've heard over the years. You just have to chuck the preamp ... sorry, John!
Frank
Old 3rd February 2013, 09:41 PM   #34130
This pot was in a JC-2 preamp a few months old, at best. It was a MANUFACTURING DEFECT and it was UNIVERSIAL .... loadsa good stuff ....
JC, thank you for these pearls of wisdom from the Jurassic days when you diidn't shy from getting your hands dirty with stinkin' measurements.
IIRC, you mentioned a wire wound pot which was your reference standard before Blowtorch.
Could you reprise your thoughts on these and explain how Blowtorch achieves its exemplary performance c/f supa dup wirewound?
You also hint at having done trials with some evil digitally volume controls eg PGAxxxx. Could you summarize your findings including any measurements you made? As these do not appear in any of your product, it won't matter if us Unwashed Masses misinterpret your measurements.
Copyright ©1999-2013 diyAudio
