| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#33291 |
If there is anyone interested, here is the complete measurement of opamps + schematics.
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#33292 | |
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#33293 | |
What happens when you reduce the gain to 20 or 10dB? Still no 7th? |
#33294 |
#33295 |
Too bad this is the last one in this test, was hoping you had some opa211 laying around.
Second law is your friend. |
#33296 |
I am sorry I wrote OPA627 in the 1st chart in the zip file, it was OPA637 as correctly stated at the measurement page.
vacuphile - I do not have OPA211, sorry. elektroj - if I reduce gain to 20dB or 0dB, there is already no 7th, but I am unable to measure distortion and noise then, for it goes below sound card threshold.
#33297 |
I don't know if this is an appropriate time, but a great deal of confusion has been generated about: not only my designs, but low noise design as well.
I personally have been working on low noise design of phono stages since 1966. I really hoped to make a solid state pre-preamp to replace the Ortofon transformer that I was using. When I read that I could PARALLEL devices, I realized that I could get almost any voltage noise floor that I was willing to invest in. However, I needed more understanding of solid state tradeoffs, before I could advance. In 1967, I visited Ortofon, in Copenhagen while on a tour of Europe, and asked them for the specifications of the transformer that they originally included, that was mounted directly BEHIND the cartridge body. This added MASS to the phono cartridge, and the transformer was necessarily very small, (compromised) as well, at the time. I was shown that future transformers would be mounted OUTBOARD so the 'mass' problem was fixed. Then I mentioned that I was still thinking of building a solid state 'transformer eliminator' and they 'showed me the door' literally, claiming that their best engineers had claimed it impossible, and therefore I was just some 'nut' wasting their time. Well time passed, and within a few months, I got use of a QuanTech noise analyzer, and I got busy. It took years to make a 'truly unique' ultra low noise design, but I had the problem solved in 1968, by using 4 paralleled 2N4403 or even better, 2N4405 (to-5) transistors in parallel, to get an equivalent noise of about 10 ohms or so. The problem then, was HOW to follow the input stage with something elegant, rather than just an add-on circuit. That took much longer. Ultimately the Levinson JC-1 appeared with a rated noise of 0.4nV/rt Hz noise at the NY AES in 1973. Of course, nobody believed it, just like today. However, it was a VERY SUCCESSFUL, if limited design (dynamic range wise) and held its own for several years, almost a decade. I could go on, but here is the point: Low noise design has been known about (what to do) for many decades. The problems are: Which devices, both affordable and available are REALLY LOW NOISE for the application they are to be used? Second: Can you make the rest of the design both well performing, and even elegant? Third: Can you avoid 'problematic' parts like input caps and biasing diodes that only add to the distortion/noise of the unit? If you can do all three, you have a good chance of making a low noise, successful audio design. Last edited by john curl; 22nd January 2013 at 02:19 PM. |
#33298 | |
#33299 |
#33300 | |
Thanks ![]() Better get those eyes checked. Mogens |
| Page generated in 0.83972 seconds (100.00% PHP - 0% MySQL) with 10 queries |
