| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#33191 |
Die size and process are about all that matters. Big power outputs probably matter in that case,
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#33192 |
That was exactly my point- the noise that Ed wants us to worry about is ridiculously lower than anything that could possibly be imagined to be significant.
If there's a sucker born every minute, where do the rest of them come from? |
#33193 |
#33194 |
Because you (maybe deliberately) didn't take care of grounding or layout properly for your test, that would be my first guess. It certainly doesn't show up in any of my gear and doesn't seem to show up in any of Scott's high precision work.
Have you published measurements showing this on the output of a 797 fed by a reasonable raw supply and a regulator, or are you moving the goalposts again?
#33195 |
Yes, as if we would DELIBERATELY screw up on grounding or layout! '-)
#33196 |
What the market will bear, just like hi end audio. '-)
#33197 | |
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#33198 |
Maybe inadvertent, maybe deliberate (to try to make a point), maybe he's switched gears and is talking about a different measurement of something else entirely. Nailing jello to a wall is not easy.
#33199 |
Because the inductances of the wires differ ?
#33200 |
Everyone, it might be important that we review how moving magnet cartridges actually work and what normally gives the best frequency response. I am looking for some classical articles from 'AUDIO' and others that might give us a better understanding.
