| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#33011 |
George,
Those results you just posted would seem to make a remote mounted trany a good idea or some form of shielding. How would you handle all of that in one of your own designs? |
#33012 | |
My approach in this situation is to say: right, the problem is not the recording, because all my experience tells me it is never the recording, or the transfer, but that a quality of the system, we have to be "strong enough" to say it, a flaw in the playback mechanism is giving me "horrid cd sound"; the intrinsic, particular qualities of that recording are intermodulating in the worst possible way with a weakness in the reproduction chain. So this is where the real battle starts, this is the garage mechanic being told that there is rattle somewhere in the car. Where? I don't know ... What's causing it? Haven't got a clue ... How am I supposed to I fix it? Just get rid of the noise, that's your job!! The "bad" recording is your rattle, and you may have to tear the car completely to pieces to finally understand where that annoying, irritating noise is coming from. But believe me, it's somewhere there; you may punch holes in the wall with frustration trying to find it, but true understanding of the "bigger picture" finally emerges when you discover the cause ... Frank |
#33013 |
Frank,
That is just to say as just in the days of vinyl recording that nobody ever made a bad sounding album. If the next ten cd's that I play sound great does that mean I have a problem or the one bad sounding one is just that, a terrible remastering of the original source tapes? If I have a great car that runs great on gas from most gas stations and at one my car runs like hell, misses and fouls the fuel filter is it the car or the gas? Nothing like water in the gas to make your day, but I sure wouldn't say I need to figure out how to make it run on contaminated fuel. Same with a poorly transfer cd, to say they all are great is just nonsense. |
#33014 |
The masters of the best sounding vinyls, if copied as-it on a cd, have all the chances to make a very aggressive and flat record.
#33015 | |
Quick sim in PSUD2. That gives very good results compared with experiment, thus its popularity.
So, managed to break the -200dB barrier yet? Quote:
If there's a sucker born every minute, where do the rest of them come from? |
#33016 | |
This said, I probably have your "bad" Doors CD album, I have 4 or 5 of them, and yes, I used them as reference pieces to work on some years ago. When my system was good they sounded very, very good; but when it was off-colour the sound of them was hideous ... I know what you're saying ... I moved on to more testing material since: try live Ike and Tina Turner material at high volume to shred your eardrums when things aren't hunky dory ... Frank |
#33017 |
If "philosophizing" means "making unsupported and probably incorrect claims about competing technologies," and refusing to admit error and learning from the experience, then sure, you're philosophizing.
#33018 | |
To me that's unacceptable. The car should accommodate the vagaries of the road, and your inputs to controlling it, in an intelligent, comfortable and satisfying way. That's why companies like MB and BMW are winners ... Frank |
#33019 | |
This presence compensate in odd that the vinyl will miss in even. But the tape sound very aggressive on flat CDs, Main reason for this 'CD sound' reputation. I was smiling, looking to the response curves of the master tape recorder: After the mix down on the console, we used to correct-it listening "after tape". So the tape's character was part of the mix itself. With digital recording, i'm not able to make the difference before/after tape. |
#33020 |
Frank,
I guess we would have to define horrid cd sound to not disagree when we probably agree about the sound of a particular album. The Doors cd that I have just sounds like I am listening to a cheap stereo with terrible balance in the sound, no real bottom end to speak of and the top is irritating to say the least. Not complaining about noise or such, just a very bad mix and eq. Given the right mastering engineer I am sure it would have sounded much better, but I sure don't want something that sounds like it was mixed on a set of NC10 speakers and tested on a set of Auratones. Just believe me that this particular cd is poorly recorder. |
