Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th January 2013, 10:10 AM   #32861
PMA is offline PMA  Europe
PMA's Avatar
This is the setup that Grooner uses to measure transfer linearity. Please note 60dB of noise gain.
Old 18th January 2013, 11:48 AM   #32862
PMA's Avatar
When I am simulating BT, for balanced input and balanced output I get this at 9Vp output amplitude. It is good, but if for John any 7th at any level (like -160dB) is an evil, he will find it even here. And, the simulation assumes perfectly matched JFET parts. 1st simulation is for some difference in output MOSFET capacitances, 2nd for absolutely same parts.
If the AD797 was measured under normal conditions (and NOT with 1000x distortion magnification as Grooner does), I am sure it would not be worse in 7th and it would be MUCH better in 2nd and 3rd.
Anyway, the level of 7th like this is absolutely unimportant, regardless BT or AD797.
Old 18th January 2013, 12:16 PM   #32863
Esperado's Avatar
I think we are talking about analog integrated circuits in a very strange and abstract way, here. I don't even now what is the purpose and why this focus on this old AD797.
An asymmetrical line driver after a potentiometer able to be driven in DC ?
A symmetrical line driver for 600 ohms professional use ?
An active filter ?
An amplifier after a passive bass/treble corrector ?
A low noise one to be part of a moving magnet RIAA P.U. preamplifier ?
A DAC buffer ?
A DC servo ?
I suppose i would chose a different device for each of those needs, and, may-be two for some of those purposes.
Christophe.
Ultimate Protection
Old 18th January 2013, 12:33 PM   #32864
Thanks PMA for your frank criticism, and your measurements. NOW, I have something to work with, but please understand: I use my CTC balanced out with 1V rms max per side, because I have a voltage gain of 27.2 following it to match THX specs. Most of the time I am below 0.1V per side, as 0.1V would give 90+ dB in my living room, and I live in a small apartment, with sensitive neighbors.
OF COURSE, if you push any design high enough, then 7th harmonic distortion will appear. However, it falls off very rapidly, according to a predictable mathematical equation so that it is almost nothing at any PRACTICAL working level. There is the problem of measuring it at working levels, Better to find 7th at a much higher level and scale down to working levels, mathematically.
Old 18th January 2013, 12:45 PM   #32865
Now just to make this clear: The Blowtorch is rated for 3V out, balanced. It is not perfect here, but at this output, a Parasound amp following it will be clipping at over 1000W in my living room. See the problem? It is absurd then to worry about its operation, even its 7th harmonic above 3V.
Of course the construction of the Blowtorch is not perfect, nothing is, and it will have more measured distortion from less than ideal components that it is made of, as well. Best they each don't contribute too much, however.
Let's get real. 7th harmonic is something to avoid. A super linear transfer function is one of the best ways to minimize it at ALL working frequencies. Feedback can help too to reduce measured distortion, but it has other problems, so I use it to a minimum, when I can.
Old 18th January 2013, 01:58 PM   #32866
SY's Avatar
OK, fine. So at that level and with that load (which I agree is absolutely reasonable), is the 7th (or 9th) of an IC based preamp significant? I restrict this question to modern ICs, not stuff from 1968.
If there's a sucker born every minute, where do the rest of them come from?
Old 18th January 2013, 01:59 PM   #32867
scott wurcer's Avatar
Originally Posted by wayne View Post
Is the AD797 the opamp to beat? Sounds like a very good test to try. I will see if any AD797's are laying about.
Please use the circuits on the datasheet, and please lets compare same load resistance I have not seen to many PA's with 600 Ohms across the input.
EDIT - Thanks PMA, I knew that SG had some explanitory text to put this in context.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 18th January 2013, 02:00 PM   #32868
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
NO!!
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 18th January 2013, 02:00 PM   #32869
Certainly, harmonic distortion measures well. That is why we use quality IC's like the AD797 in our test equipment.
Old 18th January 2013, 02:03 PM   #32870
Hi Scott, I didn't know that you were promoting AD811's to work with your AD797.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
