| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#32741 | |
It’s not that I have any real EM theory knowledge. It’s not that I dispute jneutron knowledge on this and his capacity to dig on something others haven’t. It is that there are at least two areas that this effect had a very high chance and good reason to be observed and studied by theoreticians and highly skilled engineers but it hasn’t. The two areas are 1 coaxial cables, 2 Integrated circuits (ICs) There are other areas as well (micro strip PCBs, miniaturized wave guides as used with slot phase array antennas and many other constructions in which AC voltages and minute conductor’s physical dimensions are met). IMO, if there is one case which lends itself in precise theoretical modelling and controlled experimentation , this is the coaxial line. Test of theory, test of material properties influence on the effects. Can we start from there? George
"Second Law is a bitch." - SY “Work is the curse of the drinking classes.” - Oscar Wilde Last edited by gpapag; 16th January 2013 at 06:19 AM. |
#32742 | |
Anneal temp will vary based on what you are trying to actually anneal. Last edited by Bonsai; 16th January 2013 at 06:48 AM. |
#32743 |
I found a link to one of the following at the hypex ncore thread.
This gentleman has at least an intriguing way of thinking (and doing) http://www.steenduelund.dk/download/hoerelse.pdf http://www.steenduelund.dk/download/duelund-filter.pdf http://www.steenduelund.dk/download/HJEM3.WPS.pdf http://www.steenduelund.dk/download/...correction.pdf http://www.steenduelund.dk/download/...and%20room.pdf http://www.steenduelund.dk/scanspeak8554.pdf http://www.steenduelund.dk/download/dApolitto.doc http://www.steenduelund.dk/download/kabler%20intro.pdf George
"Second Law is a bitch." - SY “Work is the curse of the drinking classes.” - Oscar Wilde |
#32744 |
Unless you have the raw chips, you'll just cause a huge amount of contamination from degradation of the epoxy and siloxane adhesives.
If there's a sucker born every minute, where do the rest of them come from? |
#32745 | |
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#32746 | |
At least unwashed people have time to listen to music while his audiophile neighbor is listening endless the same 10 seconds samples of old worn vinyls, trying to figure out the changes brought by some new magic golden cone to the reproduction of the silence after Herbert von Karajan stopped to wave his arms. The researchers tried to invent special drugs to treat them: "Blind tests". It was a failure, This disease is incurable. And expensive: with just the money they spend for their power cables, you can feed 10 African villages and their marabouts. However, i can have good time, inviting two of them for a dinner and enjoy. or just, sometimes, reading your contributions to science and your appreciation of my stereo system (you've never heard) on DiyAudio.com. Last edited by Esperado; 16th January 2013 at 12:43 PM. |
#32748 |
![]() ![]() ![]() ![]() Very funny but astute |
#32749 | |
EDIT - You also need something to getter what you want to remove, even scratching the backside worked somewhat then backside argon implant was better. With DI you might need topside gettering, all need to be part of the process.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 16th January 2013 at 02:43 PM. |
#32750 | |
At least for the current crowding effect being discussed wouldnt the co-ax symmetry prevent it all together? Thanks -Antonio |
