| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#32541 | |
The signal gain is one and since the 10 Ohm resistor is bootstrapped by the Aol of the op-amp (divided by the feedback factor), the input resistance is very large, any bench generator has no trouble driving this +-10V. ALL errors refered to the op-amp input noise, CMRR, distortion, etc. have a gain of 101 to the output. Do you really not see that? Simply consider a nearly ideal op-amp put 10V on the + input the op-amp forces the - input and the output to 10V by feedback i.e. there is no current in either resistor, the circuit acts like a gain of 1 follower, and the input resistance is very large. If need be say the op-amp has an Aol of 10^6 so 10uV appears across the 10 Ohm this is all the generator needs to supply i.e. the input looks like 1Meg Ohm. It would take 5 min to drop this into a plug board and see what this circuit does, we have used it for 40yr. The 10 Ohm and 1k Ohm have no effect on the noise or distortion (except at the third or fouth decimal place). If you want take an op-amp that is only -90dB thirds (so we can eliminate subtleties) you will see -50dB thirds at the output. jcx is right the distortion is not separable from common mode effects limiting its usefulness. BTW those app notes you guys are throwing around have some circuits that have nothing to do with this one.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 11th January 2013 at 11:38 PM. |
#32542 |
Correct. I use something similar with noise gain 80dB and signal gain 1 to reveal opamp imperfections.
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#32543 |
My pot is bigger than your:
eBay | GROS POTENTIOMETRE BOBINE DOUBLE 2x4,7K 4W 1000V MCB |
#32544 |
My device of choice for adjusting levels is a switched attenuator. 24 position devices can be obtained from a number of vendors.
#32545 | |||
Although four url links didn’t consume a lot of site’s bandwidth, I’ll explain: The two Nat Sem Appl. Notes were posted because they showed the successive progression towards the ultra low distortion test fixture for the LM4562 , starting from typical laboratory apparatus and at the same time explaining the methodology and the merits. The article of Michael Renardson doesn’t need defending. It is really good and useful overall if one has time to read it. The Xavier Ramus article caters for people not having APs to their possession. The problem is that the recent twist started from distortion, went to HD+N and I see it ending in noise. All very low level and exactly because of this, difficult to extract and differentiate between these two with analogue instrumentation. DSP methods, successful in telecommunications, could be used here. George
"Second Law is a bitch." - SY “Not to worry, audiophiles don't normally get past the Gate anyway.” - rdf |
#32546 | |
How do you achieve this 80/1 ? Using the op amp as an active filter which at some frequencies has low signal gain but it’s noise gain remains the same? George
#32547 |
Using an added switch to get 2X24 steps ?
#32548 |
Similarly as in Scott's link (Ed's image). 80dB is a noise gain and 0dB (= gain +1) is a signal gain. Try OP177 datasheet, Figure 26, e.g.
#32549 |
This is all ----. Of course anybody can make an attenuator out of almost anything, including some old TV or instrument chassis for Pots. That is not what we are talking about here, QUALITY is the key.
And what makes quality? Good engineering and GOOD PARTS. It is a shame that so many of you out there live so far away from my location. I have armloads of parts that I would love to dump on you eager attenuator makers, just to make room for the GOOD PARTS. You may not thank me in the end though, because once you made your 'attenuator' and it just sort of works OK, you may realize you could have gone to the equivalent of RADIO SHACK and gotten something more accurate, quiet, and lower distortion, especially over time, and not wasted your initial effort in the first place, even if the parts were free. Quality requires care and selection in the switches and resistors. Far more care than most of you address today. Better to stick with the simple and store bought, for most of you. |
#32550 |
Again, John, "quality" means nothing, it is just marketing blah blah.
How do-you define-it ? Price ? Look ? Reputation ? Proved long lasting ? Why an OPA with non measurable distortion, <2nv/sqHz, 50ma of drive capability, hight slew rate etc... is not Quality ? An electrochemical cap can be defined by its ESR, temperature, etc. That, i understand, but quality ? Last edited by Esperado; 12th January 2013 at 05:06 PM. |
