| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#31851 |
#31852 |
Bootstrapping for lower dynamic input capacitance lowers the DISTORTION.
#31853 | |
Is this a 2010? If so, what settings? It's obviously not the 1/3 8ve filter set ______________ Where did you get your 100G resistors in 1974? This would have been of considerable interest to me around that time. What physical size roughly ? ______________ Err.rrh! What IS your point? Last edited by kgrlee; 28th December 2012 at 07:28 PM. |
#31854 | |
From Jurassic attempts to find vinyl with high slew rates and also some mike trials, the only musical signals above 20kHz would be cymbal crashes recorded close up. Anyone know different and can show examples? IMHO, musical content needs to exhibit the characteristics of music. eg dynamic range; remember loud bits and soft bits ... unlike modern 21st century noise. ![]() PMA, do you know if the vintage Telarc stuff issued shows dynamic range above 20kHz? From what I know about their mikes, it is possible. Scott, excuse me if I exclude some of your exotic instruments from foreign lands. ... but if you can send a beach bum a recording or two, he might be persuaded that these are music. ![]() ________________________ Frank I think you were asking about detailed microphone distortion measurements over a large frequency range. I can say these are quite hard to do from experience circa 1980. The only published stuff I've seen is several Sennheiser AES papers where they show the THD advantage of their symmetrical RF mikes. However, the 'conventional' evil examples in their paper are not really representative and it is trivial to have better performance. Their mikes are excellent but in fact suffer early overload for other reasons which might be more important to a recording engineer. Last edited by kgrlee; 28th December 2012 at 07:44 PM. |
#31855 |
Who cares?? SE tubes distort like a hell, and they are considered great sounding by many. Not me, thanks.
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#31856 | |
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 28th December 2012 at 07:34 PM. |
#31857 |
Other than output stages, nonsense.
If there's a sucker born every minute, where do the rest of them come from? |
#31858 |
Agree. Particularly to the extent that a triode follows the ideal Langmuir-Child characteristic, a very-lightly-loaded common-cathode- or common-anode-connected one has extraordinarily low distortion. Of course most triodes are not ideal, but many are very good within the middle range of biasing.
However PMA probably did mean SET power amps with significant plate loading. |
#31859 |
Especially output stages, but common cathode simple stages as well. It is very audible, but who cares?
#31860 |
kgrlee,
I am not so convinced that there truly isn't any information above the 20Khz range as much as the present multi-microphone recording chain just can't get the phase response correct so that we can reproduce this information in any coherent way. If the phase response and timing was correct then we could talk about it, but that is the problem with most of what we are always talking about in upper frequency reproduction. I in-order to reproduce the sheen of a cymbal or overtones from other instruments we would have to get that correct or it is just smeared in the reproduction and then we just hear it as noise. Just my opinion of what is going on in the reproduction and recording chain. |
