| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#28901 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#28902 |
#28903 | |
And, what stops people who do know from using a combo of 8 and 9kHz ... unless, it might be too revealing ... Frank Last edited by fas42; 5th November 2012 at 02:38 AM. |
#28904 |
I might have done this in 1980 but this is beyond my brain capacity this millenium. Yus gurus, please point to something that dun nid Higher Maths for Dummies. I'm sure there's loadsa stuff if you have done HM4D.
#28905 |
Harmonics and IMD both come from trigonometry. Take two sines (or cosines or one of each). Multiply them together. There are trigonometric identities which tell you how to write the result in terms of other sines and cosines involving the sum and difference of the angles. That is how harmonics and IMD are formed: multiplying sines together in non-linearity.
Yes, when you slaved over triangles as a bored teenager in school you were learning the mathematical basis for low distortion amplifier design, but unfortunately the teacher never told you because he probably did not realise this himself. |
#28906 | ||
)Quote:
jn |
#28907 |
If you are playing at moderate-high levels in a large living room at listening distance, then up close to driver the spl is huge! As is distortion.
Measuring thd at 1W at 3 feet doesnt begin to tell you what you are really hearing/producing at the listening position under normal (for me) listening levels out in the room. I would imagine same for horn at throat entrance.... very high spl and distortion. Distortion is a Lot higher than typical measurement conditions/specs imply. [Just use an SPL meter.... set up listening level out in the room's listening position and then move the spl meter to the driver up close (inch) and measure.... you get really high spl, then. What is the driver doing at such high spl?] I measured once very high thd under same real world conditions. -RNM Last edited by RNMarsh; 5th November 2012 at 02:18 PM. |
#28908 | |
This is signal processing 101, even Wiki summarizes it nicely. Even and odd functions - Wikipedia, the free encyclopedia
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#28909 |
I was told a trumpet at full throtle was about 4W at the throat. A small silicon pressure guage could be placed at the throat of the waveguide/horn, an interesting experiment.
#28910 | |
Of course, besides breaking up the intragroup camaraderies (and rivalries?), perhaps a bit of this IM is part of the particular arranger's sound. |
