| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#28041 |
The Audio Guild |
#28042 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Frank was asking about H field emissions - these would be right down the bottom of the list of worries for a PC.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#28043 | |
se
The Audio Guild |
#28044 |
Oh, I saw a question mark - so it seemed he was asking if they were and I was replying that its far from the main issue with noise from PCs.
#28045 | |
An issue for audiophiles -- the prolific SMPS can produce both field coupled and direct coupled noise. EMI/RFI government specs from equipment is typically directed to aircraft and emergancy, police et al frequencies and are tested to comply by agencies such as USA's UL. However, those tests and freqs are far above the audio range and thus audiophiles need a lot better performance than UL qualified equipment provides. And, they dont cover the direct-coupled issues into the ac power lines. Thx-RNM Last edited by RNMarsh; 9th October 2012 at 12:02 PM. |
#28046 | |
The logic circuitry itself.
http://www.youtube.com/watch?v=xZmfCYr8mwA |
#28047 | |
Very much so, home and woik.
Finishing up a bathroom reno, so my clock stuff is on hold. Doing the radiant heat next. Exactly. Moreso PC's though, Apple really paid close attention to EM radiation. Quote:
Ground loops will also help M fields launch. E fields are generally the easiest to stop radiating. M fields are the hardest. jn |
#28048 |
Wait a minute! like an earlier post said! T&M gear like a tek scope; Not good enough shielding? Those don't cost 3K to fab.
Robert Lounge Audio |
#28049 | |
The product was quite successful. Some mistakenly imagined that it was USB-powered since around that time a patent of mine issued for managing such (6178514). Another engineer supposed that the four drivers per satellite were driven in some sort of complex phase relationship (and warned us about Bose patents, which he was never able to produce ). But no, it used an a.c. adapter, and the drivers were acoustically in parallel while alternating in magnetic polarity to partially cancel adjacent monitor distortions.At one point, since people were frustrated that they couldn't use analog sources, Plunkett changed the design to an analog-input version and added touch controls for volume to a redesigned satellite base. |
#28050 |
And the case of the satellite speakers made great incense burner trays
