| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#2421 |
The one and only
#2422 |
Pretty difficult to believe.
#2423 |
#2424 | ||
Hi Andre,
I like using Canare wire personally. It has the added advantage of being very flexible. Quote:
-Chris
"Just because you can, doesn't mean you should" © my Wife |
#2425 |
#2426 | |
The problem was the inability to reproduce any frequency response within 0.1dB. Obviously, no resonances were encountered up to 100KHz. |
#2427 | |
Banned
So your position is that resistive loading of a MC is inaudible? |
#2428 | ||||||||||||
Hi Joshua,
While it is very true that the higher harmonics do seem to be picked up more easily than low order harmonics, singling out the 7th might be too optimistic. Yeah, I know John likes to look at this number, but you can't isolate one harmonic. You must look at all of them. You'll generally find that the absolute level of the 7th harmonic is related to all of them in the series. They all vary as each other in the higher harmonics. Looking at several spectrum "pictures", it can be seen that the 7th may be of a higher amplitude than it's neighbors, but you also have to look at the actually frequencies of these harmonics. For instance, if someone can hear to about 16 KHz, the 7th harmonic is only important to about 2.3 KHz for that person. For a claimed normal of 20 KHz in a younger child / teenager, you can move that up to about 2,860 Hz. The ability to hear problems diminishes rapidly after that, especially since these harmonics are very low in level. Zeroing in on one specific factor (like the 7th harmonic) posses a very real risk of missing the more important measurements. You need to look at the entire picture in order to come to a valid answer. Note: John, I am in no way "attacking" your interest in the 7th harmonic. I am specifically answering Joshua's post. I am more than certain you know what and how to measure audio equipment. Quote:
![]() In truth, you should listen to all well designed, well made equipment in your price range. For example, Nelson Pass has designed commercially successful equipment that are different in the most fundamental ways. To do anything else is simply to restrict your choices, but then that is your problem. For example, I've had poor luck with every single Ford I have ever bought. I've had three now, and each was a disaster in it's own little way. All suffering from poor quality. However, I'll still at least look at them and test drive. You know what their slogan is? Have you driven a Ford, lately? They say this about every 8 years and haven't really changed. Quote:
![]() See above. Quote:
-Chris
#2429 |
I was told of another definition of PhD, it is 'Piled higher and Deeper' ;-)
#2430 |
Banned
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| riccoryder, john curl |
| Page generated in 0.29801 seconds (65.34% PHP - 34.66% MySQL) with 11 queries |
