| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#2381 | |
The notion that an amp that changes its sound due to a cable is somehow a good amp is totally alien to me. It would actually make me doubt the competence of its designer. I do know that there are some cables marketed that have been deliberedly engineered to sound as different from another cable as possible and that the difference in itself is often interpreted by the inexperienced as 'better', but that's another matter entirely. jd
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#2382 |
My own heretical penchant for flea powered Class D amps,leads me to ponder a class D preamp miight be fun.
I always admired those millimetric pcb techniques. regards Max Albin Ps I'll get my coat. edit pps poppy Last edited by albin; 8th November 2009 at 10:32 AM. |
#2383 |
I should add that in the case of such a cable that has a clear effect on sound (and I have heard often these differences), I could always measure the causes, like a pathologically high capacitance in interlinks coupled with a finite output impedance of the source or preamp.
Even with a source or preamp with very small Zout, you still can have effects on stability with very high capacitance cables that can be audible sometimes. So I admit it is not always easy to design an amp or preamp that is immune to cable effects, but when there IS an effect with a good amp, my experience is that it is measurable, and not subtle. jd
#2384 | ||
#2385 | |
#2386 |
What is wrong here? Why are you talking about cables? I haven't mentioned cables recently, on this thread, and 'everybody' knows that it is not rational to talk about differences in cables.
I have been concentrating on phono cartridge loading. Apparently Syn08 has been, as well, as he designed quite an elaborate one with his phono amp project, available for view, just below this thread. In fact, his input loading is even more elaborate than the one that we put into the JC-80, 25 years ago. Now, I am asking him for his reasons, especially those based on measurement, as to why he would add such elaborate loading to his design. This is the question. Once this question is answered, THEN we can go forward and talk about cables, if you want. Off comments so far, about cable, are riddled with subjective opinion that 'holds no water' here. |
#2387 |
It would appear that I am not going to get further input on MC cartridge loading. I hope that some here, learned something new. It is not immediately obvious that MC cartridge loading has so few measurable effects, but that is the case. It is much the same as connecting wires, even though many here will not believe it to be a similar situation. Perhaps that is because it is difficult for someone to manufacture a special MC load box and make money from it. Not so, with cables.
#2388 |
Can someone provide an accurate technical description of how cables effect sound?
#2389 |
MC cartridges are low impedance sources,but surely someone will tax them,probably severly.
regards Max Albin |
#2390 | |
In my own preamp, I saw a large difference between loading with 68R versus 680R for my 15R source impedance MC, but maybe THAT is the special case, not the sort of preamps that you or syn08 design.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| riccoryder, john curl |
| Page generated in 0.26237 seconds (62.22% PHP - 37.78% MySQL) with 11 queries |
