| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#23371 |
Not good, is it?
#23372 |
DF96, it is a little more complicated than this simple example, but the principle is correct. Balance is useful and 'necessary' in the CTC Blowtorch.
#23373 | |
Why don't you address the point of my post, John, instead of wandering off on some obfuscation?
se
The Audio Guild |
#23374 |
If you need balance, why not insist on it by having suitable supply arrangements? It seems perverse to design a circuit which requires exactly balanced supply rails, then run it from a PSU which is guaranteed to provide unbalanced supply rails unless the circuit draws exactly balanced currents. I assume you felt there was a good reason to do it this way.
#23375 | |
http://www.youtube.com/watch?v=xZmfCYr8mwA |
#23376 |
It is attached, actually. But attachment is modulated with 120 times per second speed. It is the matter of preference.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#23377 |
With the power supply I am working on which has < 1mOhm @1500 Hz,the difference by closing the switch would be something like 2,2 uV. At DC it would be much less, but have no way to reliably measure. Problems are lay out and higher frequencies. You can make supply with extremely low output impedance, much lower than realistic pcb-traces would add. So that also means: where would you connect that LED, to see what the effect on the voltage at different points would be? vac
Second law is your friend. Last edited by vacuphile; 28th May 2012 at 12:03 AM. |
#23378 | |
#23379 |
Good Idea Wavebourn, but is the plastic stick also conductive enough to be an RF barrier?
#23380 |
Things sort of got quiet when I brought up the 'balance' example. Any questions?
