| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#23241 |
Jfets are OK. They are NOT as good as tubes, part for part, in linearity. They can be quieter, and they are complementary, so they can be made to be excellent gain stages. Break-in is, to me, a physics problem, that I must acknowledge, to be difficult to 'prove' but easy enough to hear. Break-in for me, is important, but in the total connection and wire sense. I recommend it.
#23242 |
In the hills
I like tubes just fine have designed with them and even own some but do like SS consistency and reliability. Very true about break in quite audible doesn't make 100% sense but it is there, our ears are pretty damned good tools still and ear owners buy the product.
#23243 | |
i started by swapping the resistor out, turning it around, different types, brands, models, solders, each time, a full and proper burn-in in. Skinning the resistors (naked), different mounting, wearing out the leads, via stressing, every thing I could think of. plating the leads, unplating the leads, different field conditions, demagnetizing, etc. It took nearly a year to really get a solid handle on the overall aspects of each and all of those considerations, but since it was the most critical spot in the amp, it ended up explaining much - about all else. This was in the early 90's. I had a couple of basic amp models I used, specifically ones with high feedback, so the effects were multiplied and they (the amps) also had a low number of parallel outputs, so I could actually hear those micro differentials. Last edited by KBK; 24th May 2012 at 05:42 AM. |
#23244 | |
Is the advantage in thermal (overall and related issues) better than the cumulative effect of the rest? Only the specific result in the specific experiment will tell. Too many variables. My ears said you were right, in most ways or the more 'noticeable' considerations. Last edited by KBK; 24th May 2012 at 06:10 AM. |
#23245 | |
#23246 |
One main aspect for tubes is their their thermal stability (minor shift in the operating points). Disadvantage is their (more) limited lifetime and that you need filament supply.
#23247 |
In solid state devices, there are big shifts in the device paramters with the signal voltage. There is a discussion on some of this stuff over on Edmond's thread. A classic example is Cob in a VAS transistor, or the input capacitance on mosfets and JFET's. Designers need to be aware of this stuff, because often it frigs with overall stability.
Now, you overlay the thermal impact on device parameters and its clear nothing is really nailed down. Circuits just flop around, hopefully not banging into any serious limitations. Maybe tubes sound good because they run hot (thermally stabilized?) and the paramters don't shift that much with signal - but I am not a tube expert . . . ;-) |
#23248 | |
This stuff has been trade secrets for folks making 18bit + modular A/D's and DAC's for decades.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 24th May 2012 at 02:50 PM. |
#23249 |
#23250 |
Ed, you keep pointing that stuff out like nobody ever heard of it before. I once scavanged a discrete DAC made for the missile program in the 60's. It used 2W 1% resistors for an 8 bit R2R ladder.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
