Go Back   Home > Forums > Source & Line > Analog Line Level
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 4th November 2009, 09:56 PM   #2301
Well, maybe we can get machined chassis in the USA at an affordable price! Yea!
"Condemnation without Examination is Prejudice"
Old 4th November 2009, 10:51 PM   #2302
Production in China or India will be cheaper – but probably you'll have to be there physically, to make sure it's being done according to specs …
Old 4th November 2009, 11:27 PM   #2303
If it were only so easy, Joshua. Do you have any feeling for how many chassis per year that I am indirectly responsible for that are made in China and Taiwan?
Of course, American made costs more, because Americans have bigger personal expenses in order to support themselves and their families. If you don't make MANY of the same chassis, the Chinese just won't do it. Why should they?
Old 5th November 2009, 12:12 AM   #2304
ikoflexer's Avatar
If I thought you were seriously considering lower cost high quality chassis manufacture I'd point you in the right direction. But since it's just academic...
OK, back to noise and noise cancellation/attenuation. It seems to me that there are two schools of thought. a) Do noise attenuation in the power supply, and b) do some of it in the psu, and some of it in the circuit itself. Examples of the latter are using CCSs as loads, opting for push-pull topologies, or something like the aikido circuits.
I'm probably leaving some out, but you the experts can fill in and correct me.
Option b) implies a circuit with good psrr. syn08 has repeatedly said that this is good engineering, and that option a) is bad engineering. I don't want to single syn08 out, but he's been the most recent to say this and most vocal about it.
One of the advantages of being a beginner, like me, is that I start from zero. Even better, I'm not an engineer. (you can start shooting now)
So naively I think: hm... I like things to be separate. I read all sorts of threads about amplifier design and get the sense that it's very difficult to keep things clean and simple. Especially to keep a signal undistorted. And then I see that, for instance, the aikido circuit has a noise canceling stage for each amplification stage. Right in the middle of amplifying things, there it is, the thing trying to manipulate the signal to take out only the noise, and leave the signal intact.
How about the single-ended with CCS load, that gives that so much wanted psrr? It does look a little like part of the regulator/filter moved very close to the amplifiers (and it also became the load, while at it). Other people take it out and put it in the psu, add a capacitor or two to it, and call it a capacitor multiplier, or a gyrator, or whatever.
I wont' even touch the push-pull thingy. It's something that I don't feel good about.
Is there more to the picture? Am I missing something really obvious here? Dear experts, please be kind to a beginner.
Shunt reg latest:positive rail revision 5k
negative rail revision 5d and new: E-MU_0404_USB_mod_wiki
Old 5th November 2009, 12:19 AM   #2305
I know, John, I was joking. In me previous job I've dealt with Chinese mold makers and I know it isn't worth any ones while for small quantities.
Old 5th November 2009, 12:36 AM   #2306
ikoflexer, not being an engineer myself, but having a lot of experience as an electronics technician and an audiophile, these are my simplistic thoughts on the matter:
First, any amplifier would better be designed with highest sound quality as the major goal. PSR would better be considered, however, only as a second goal.
Second. Once the amplifier design is complete, the needs from the PSU should be looked at and the PSU should be designed accordingly.
Generally speaking, the quieter the PSU is, the better – as long as line regulation and load regulation are maintained at appropriate level and as long as its' production cost is reasonable, or within the overall project's cost. Once the amplifier's PSR is known, the degree of possible compromise in the PSU's design is known as well.
So, it may be an overkill to design a super quiet (and expansive) PSU without knowing the amplifier's requirements. Also, there are different considerations for a class A amplifier, vs. class AB one.
Old 5th November 2009, 02:18 AM   #2307
Everyone contributing to chassis construction. I appreciate each and every input that gives some information on how to do it better or cheaper, or both. However, off hand remarks like: I could get it done for 1/3 the price, doesn't float my boat, or actually give anyone else any meaningful info, either. Joking is not part of the package.
Old 5th November 2009, 04:08 AM   #2308
Send a message via Yahoo to kannan_s
John
what happened to your welding the Aluminium chassis try out. Welding would have avoided using large mass for the milling out substantial amount of material. Ofcourse the welding method is specific to Alumunium. It is not easy like welding steel - requires TIG /Plasma or Laser welding under inert atmosphere like Argon- expensive. This process would have saved cost in my opinion or your experience is otherwise?
kannan
Old 5th November 2009, 04:15 AM   #2309
We tried welding with the first prototypes. In fact, Jack Bybee has one of these early cases, surrounding his CTC preamp. However, it was too difficult to do it right, so we went to 'hogging' the cases out.
We have made many cases over the years in the USA, where my associates and I were responsible for making them properly. We tried plastic, sheet metal, machined sides, aluminum welding, and finally hogging out. Each has its good points, and bad points. However, nothing comes for free, and really good does not come cheap.
Old 5th November 2009, 04:28 AM   #2310
Wavebourn's Avatar
In radio manufacturing when such things are needed, aluminium pressure cast is used, then some surfaces are machined in needed places.
Amicus est Socrates, magister meus, sed magis est arnica veritas.
Thread Tools
Page generated in 0.14608192 seconds (71.20% PHP - 28.80% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
