| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#22991 |
price is easy to adjust upwards - limited only by case appearance/weight/finish
not quite so nose bleed but look inside Ray Samuels Audio products - US$3k Dark Star headphone amp is 4 bridged OPA541 power chip amps - worse audio specs than LM3886 but really nice machining on the case, separate ps box, cones... another example is a US amp manufacturer who contemplated closing, as last gasp effort went from sheet metal to machined cases, careful matching anodize apperance, integral eye candy heatsink machining, "jewelry" connectors - and 3-5x price increases in an hr presentation at BAS they never once mentioned actual circuit design changes - now a regular buyer of full page Stereophile ads - doing great business Last edited by jcx; 10th May 2012 at 02:52 PM. |
#22992 |
Write-Off
A new 750 does $45K here, used ones go under 20 (gets even worse when the 750PSU unit is included. one might think coils are a bad investment)
Not so much,.......if it says "ZM" in the corner. |
#22993 |
No, you just need to pot it in diamond inpregnated epoxy (for its thermal properties of course).
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#22994 |
I see nothing but "8 legs" here what's up? Is that photoshop or did they go through the trouble to really mill off the markings?
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 10th May 2012 at 02:51 PM. |
#22995 |
Output stages are discrete Class A, rest is opamps (and coils)
#22996 | |
![]() Nice component choices. By some random chance the parts they are using are among the ones that measure well. |
#22997 |
Well you're doing something wrong, those guys are laughing all the way to the bank rolling IC's. Costs a lot more than the BT and looks like a lot less work and TAS thinks it kicks butt.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 10th May 2012 at 02:57 PM. |
#22998 |
Slightly off topic. We are shipping out a small system this month. It is taking six trucks just to hold the loudspeakers. We book an entire truck to take our loads. Twice now, the truckers have tried to pick up our stuff and pack it tight enough so that they can pick up a partial load from someone else along the way and make a bit more money.
Our best technique to avoid that is that our crates are four and a half feet wide so that you can't put two next to each other and a standard four foot pallet won't fit either. We do pay for the entire truckload for a good reason. The maximum insurance for a truckload is $100,000! So we have to keep each shipment under that. So you would need a 53' truck just to carry two phono preamps! ![]() Scott, That means you could only get 7 ICs on a truck! |
#22999 |
2 DIP8 heatsinks, 1 BB
#23000 |
Where are the discrete parts? Are there dual transistors in the heat sinked DIPs? The pinout or what I can make of it doesn't match any discrete that I know of. Looks more like a power buffer like the LT1010. Fixed bias? They aren't even using IC's in cans or ceramic packages. Where are the coils? Are you sure this isn't just the servo?
Demian Martin Product Design Services |
