| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#20001 | |||
You are scratcing the core of a long standing –still hot- debate among the supporters and the opponents of Plato’s expressed ideas over “knowledge”. Don’t expect to reach a consensus in this lifetime ) George
"Second Law is a bitch." - SY “Not to worry, audiophiles don't normally get past the Gate anyway.” - rdf |
#20002 |
Well, now I'm thoroughly confused. You published them, you didn't publish them, now you published them. When you figure out if and where where you've published detailed descriptions of test protocols, methods, controls, data, results, and analysis, I'll be interested to read them.
If there's a sucker born every minute, where do the rest of them come from? |
#20003 |
I found Jakob2s answer clear enough. Why are you confused ?
Regards, Georg |
#20005 | |
To me, neglecting the internal inductance is a clear and obvious test violation, but since I live and breath this kind of test stuff, my experience may be the only reason I spotted it. When I first encountered his published waveform, I was shocked that it was an exact duplicate of one I dealt with a few years prior. The upshot of my analysis and fix was that the diode being tested did not have a Trr of 5 milliseconds, but that the 250 micro-ohm CVR was collapsing it's field and the test system was picking up the flux of the CVR. Since the CVR was a set of 11 copper plates 4 inches by 4 inches by about 100 mils, I simply had the tech run a wire down the geometric center of the resistor...that eliminated the flux trapping and solved the problem. (pic attached, it's fuzzy cause it's through a 1/4 inch lexan blast shield..) It did not require I define some new entity via planar wave field penetration to describe the "new phenomena", just an understanding of ampere's and faraday's law and how they can bite ya if you're not careful. Cheers, jn ps. The article initially cited was published in stereophile october 1995, starting on page 53, ending on page 69. The 70 page document mentioned by John Curl was called a Unification document, comprised of many "tracks", and on my computer it comes out as 88 pages. Page 70 is where the conclusions begin, at the bottom...and the following pages are appendicies, test diagrams, and matlab code he generated for his simulations. The unification doc was a series of publications in HFN/RR, starting in may of 86. Last edited by jneutron; 27th January 2012 at 01:20 PM. |
#20006 |
People always seem to be surprised, and cry "distortion!", when the waveform at the output of a filter is different from the (non-sinusoidal) waveform at the input. Did they expect just a change in amplitude and a bit of time delay? Hawksford carefully navigated around this particular mistake, by admitting that the system was linear and so could not generate new frequencies, but then threw a bone to the cable freaks by muttering about grain boundaries etc. Trying to have his cake and eat it?
Maybe someone on here with the necessary software to hand could publish the spectrum of a short unprocessed zero-starting (and finishing) tone burst, so that others can see what a wide band it covers. To make life easy, you could assume a burst repeat frequency which is an integer sub-multiple of the tone frequency. Then put it through a first order low pass filter with rolloff well above the tone frequency, to exhibit the 'distortion and time smearing' which appears at the leading and trailing edges. I think this would be educational for those who have never actually calculated a Fourier series themselves. |
#20007 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
@DF96 - download Audacity (its free) and you could probably do it yourself. I know I've created a toneburst with it in the past, and it has the necessary FFT capability.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#20008 | |
#20009 |
I scored 100% without even listening to the music at an AES demonstration by listening for the A to B and B to A clicks.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#20010 |
Do you think folks will ever stop trying to PROVE digital audio is flawed by using waveforms that violate the sampling theorem?
| Page generated in 0.69749 seconds (100.00% PHP - 0% MySQL) with 10 queries |
