| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#171 |
Jacco, he was afraid of quality of a cap used in a feedthrough, so I suggested to make own with a good cap
#172 |
Hi Pavel,
Given the values you are looking at with a feedthrough capacitor, any low K ceramic material should be fine. Talking about power supply feeds and amplifier outputs, they are low impedance circuits, so even a high K ceramic shouldn't represent any problems. Input circuits should be easy to deal with as well. Wouldn't a length of shielded RF wire act as a feedthrough capacitor the shield was grounded at the point of entry through the casing? I have used these off and on, usually when dealing with higher frequency circuits. RF amplifiers and switching power supplies certainly rate here. Hi stoolpigeon, Demian, A new thread for this would be the best. It would be a shame to confuse two designers and their ideas, and Demian deserves a thread of his own to discuss his ideas, if desired. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#173 | |
expert in tautology
by "ferritic" do you mean non-magnetic? _-_-bear Edit: oh, where are we on internal PS vs. external PS, especially WRT that choke shielding issue? Do we want only DC sent through the embilical connecting cord, and what about ground if we go external??
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#174 |
Chris, I use professional HF feedthroughs, they are also a part of my current preamp design, to clean DC PSU output wires thru an Al wall.
#175 | |
The inductance stayed the same, due to the mix of copper and ferrittic stainless steel. I have not had a need to push it past 10A, till that point no saturation occurred. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#176 | |
Ferrittic stainless steel is the type that is magnetic. It's rather rarely used, but for this it made sense. Magura
#177 | |
expert in tautology
This is an interesting question, but this is the Blowtorch thread, not the Borbely thread. Erno has some interesting design ideas, and it deserves its own thread, imho. You might want to start a thread on Borbely designs, post the schematic you are referring to, along with a jpeg of your implementation and a block diagram of your wiring/ground scheme?? _-_-bear
#178 |
You will have almost nothing to discuss here, then, maybe cars and wines.
#179 | |
expert in tautology
_-_-bear
#180 |
Epcos B85321, metallized polyprop foil capacitors.
Manufactured in values up to 4.7uF, and subsequent 6''x2'' sizes. (= what i use to go through 10mm Alu walls)
Not so much,.......if it says "ZM" in the corner. |
