| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#17941 |
Is this a trick question? You need to identify the op-amps and define signal correlated noise.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#17942 | |
As to noise, does the noise level increase when signal is present? (Pick any real op amp for that question.) What contributes to the increase in noise level? |
#17943 | |
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 15th November 2011 at 05:13 PM. |
#17944 |
we could probably list a few 2nd order effects - most not unique to op amps - any transistors, resistors will show some level of noise modulation with signal
bulk metal foil R are "the best" on excess noise, TC - but we've been told they don't "sound the best" and these 2nd order noise modulation effects can be orders of magnitude less than the Zoo of analog magnetic tape noise artifacts Last edited by jcx; 15th November 2011 at 05:52 PM. |
#17945 | |
#17946 | |
The issue is that in a real circuit there is always noise. Some of it comes from the active components, others from the passive parts and still other comes in from the external connections, such as input and output leads, along with the well know power supply issues. Which noise source is dominant? What happens when you have two noise sources and a non-linear channel? With matching inverting gain stages some distortions cancel and the result can be better than predicted by simple feedback assumptions. In the case of uncorrelated noise the math is almost clear. But in all real amplifiers there may be some bandwidth modulation due to signal and or slew rate limitations. Does this influence the noise? If there is a signal related correlated noise what is the bandwidth of such noise. Can this noise conjugate with other stage noise to produce correlated artifacts back in the audio band? At what levels do these issues occur? |
#17947 | |
#17948 | |
John |
#17949 |
I guess that's all you can expect from a vanity lable. Lyrita had some excellent stuff in their catalog that I enjoyed a lot more. Nonsuch's Geroge Crumb series is still one of my favorites even though groove pre-echo is obvious on several tracks.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 15th November 2011 at 11:30 PM. |
#17950 |
