| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#17501 | |
http://www.bksv.com/doc/articles/dynx_tech_article.pdf |
#17502 | |
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 3rd November 2011 at 11:25 PM. |
#17503 | ||
It achieves (specs) a full 24 bit DR at 48k. They are an interesting company that has a mix of seemingly cutting edge digital design with some traditional hi-end subjectively driven design. An example is the abundant use of open loop circuitry. Even their power amp is void of global or inter stage FB, so it won't win any numbers races. Gets great reviews though. |
#17504 |
Maybe from a 1 Ohm source impedance.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#17505 |
Not the case, but it's irrelevant anyway.
I presume they would only get those numbers in low gain IP mode, 0dBFS = 9.3V RMS. I don't have to tell you this a bit over 4nV/rt Hz which is achievable, if only on the test bench to verify the spec. Regardless, if this is in fact a true spec then I say good luck to them - I'd like a dollar for every stupid thread I've had to wade through that argued the merits of 24 bits and the ability of ADC's to even come close. |
#17506 | |
#17507 |
B&K?
#17508 | |
The most I've seen is the claim that listener testing revealed no detectable advantage beyond triangular, but at the same time those tests certainly did not indicate that Gaussian or other dither of a higher order (>2) was worse than triangular. For those specific tests, my first reaction was to intuit that future tests on better equipment might make it possible to discern finer details that might put higher-order dither at an advantage. In other words, my take away was indications that people can clearly hear problems when there is less than 2nd-order dither, but above 2nd-order dither the results seemed inconclusive. Do you have links to specific articles from Widrow, et al? |
#17509 |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
#17510 |
If by REAL we mean that they measure 24 Bit ENOB or more, no. The ESS Sabre currently leads the field with around 22 Bit ENOB on the DAC Side. Plus, I kind of take exception to the use of lowish bit parts with dither to get there, though some disagree. On a hardware level the ESS Sabre has enough hardware resolution to handle 16/44 directly (no noise shaping), which is probably why it reportedly sound so good and is so much better than competitors chips. They have given the Chip enough real resolution to take on old multibit chips, but the penalty is a very large die and a cost that makes you think of buying a pair of K Grade PCM1704 instead, if you are me... If we mean with real 24 Bit's implemented in a multibit architecture, there is the TI/BB PCM1704, however it's ENOB is more like 18.5 Bits. You can theoretically parallel several and implement "analogue oversampling" into the bargain, with 16 pcs in parallel you should get 20.5Bit ENOB without any mathematical tricks. Then there is the MSB DAC, but last time I looked you could not buy it (internal use by MSB only) which is what we called a hybrid integrated circuit in the old days and the long announced Arda Tech DAC, which to this day appears to be lacking shipping silicone. If you are lucky, the PCM63 and AD1862 can still be found despite being long discontinued. Both are "only" 20 Bit but they offer close to 20 Bit Enob and as they can run at 8 or 16 Times Oversampling one could combine them with a PWM Modulator to gain 8 or 16 more levels, which is 3 or 4 extra Bits... Ciao T |
