| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1421 |
diyAudio Editor
Thread is open..
#1422 |
I would like to ask PMA, in particular, from his circuit analysis of the j-fet Comp-diff 4 quadrant folded cascode preamp model, what he thinks the effective open loop bandwidth is with 1K loads.
#1423 |
Just to remind those new to this thread, the 4 quadrant complementary differential j-fet, mosfet topology is what the CTC Blowtorch used to buffer the line pot and to amplify the audio signal.
Perhaps someone from the past can put up a simplified schematic, so we know where to start. This design is at the heart of the CTC Blowtorch and most of Charles Hansen's Ayre designs. It is particularly useful for open loop designs, We could also talk about and compare 4 quadrant all j-fet, non-folded cascode designs as well. such as is in the Parasound JC-2 preamp, just released this year. The 4 quadrant differential is not a new topology, as I first used it 40 years ago with bipolar transistors. However, with cascode, it gets even better, especially with j-fets. |
#1424 | ||
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#1425 |
I still think that a Telefunken schematic would be interesting to discuss.
My only Telefunken schematics are from quality portable radios from the 1960's, including one that Dick Sequerra worked on. However, even though they are very good sounding units, they are made with germanium transistors that are difficult to get today. In my opinion, we should start somewhere, not changing from A to D, or amps to mikes. It makes it more useful, that way. |
#1426 | |
![]() First of all, you need a plan of the course. No doubt, you have some already, you may start from physics and technology of semiconductors. Then, 24/7 duty, voluntary. Are you ready?
#1427 | ||||
Hi John,
It was closed for reasons different than what you attempted to pass as a true reason. Can we call a halt to "putting down" other members, this forum and it's moderators from now on? The same would apply the other way. No personal attacks allowed towards you. In other words, let's keep everything professional. There is no room for egos here. Quote:
-Chris
"Just because you can, doesn't mean you should" © my Wife |
#1428 | |
Hi Anatoliy,
I don't think it's up to MJL21193 to plan the course of the thread. That's a bit much to ask. How about simply letting the thread find it's own way, and stay away from directly commenting on John's design in this one. I know you were joking a bit here Anatoliy, but it is a great idea. Would you like to start it? MJL21193? Anyone? I can, but we should give someone else a chance at the mechanics of it. -Chris
#1429 |
One of the best examples of the 4 quadrant folded cascode topology was put up on this website, by Justcallmedad, on 5-30-2006. This is a fairly easy to read schematic, and only has a few 'extra' resistors that could be removed without changing the circuit, fundamentally. I do have a copy of it here. However, it should be in the website files as well.
#1430 |
A new thread ? With a more professional atmosphere ?
![]() Amps to mikes ? .. power amps , headphone amps , preamps .. they are all amps. One amp design can be applied to another amp. To discuss germaniums , the "sound of tubes" , would not be too "offtopic" if it helped others to understand the history and theories behind the designs. State of the art ? Surely, BJT amps could be "new" , maybe even embracing SMD's (aussieamps) , microprocessor control (syn08) , but SOTA ?... this would be in the realm of mean, green Class D. (I personally do not believe this) "Design principles" would be good for us "greenies" , we could hear the opinions of those "hardened ones" and ask questions (without being put down). Sounds good in concept ! OS |
