| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#13361 |
Keep plate load high, cathode impedance low.
You could reduce that tube count and get far better performance without adding feedback or rely on very imperfect cancellation. 12AX7-oids are incredibly linear under high plate load/ constant cathode voltage conditions. You just need to buffer them a bit to keep the plate load high. Horshak, not Epstein.
If there's a sucker born every minute, where do the rest of them come from? |
#13362 |
There is no need to reduce the distortion in well designed triode stage. Some of the best tube pre-amps and phono stages do it with a great success, without negative feedback. Even SY did it in his phono stage.
#13363 |
#13364 | |
as the tube experts explained in the thread I linked the internal feedback from the anode V being visible to the grid has a similar nonlinear power law as the gm, giving a low distortion, internally feedback fixed mu |
#13365 |
Reference to an American TV show in the late 1970's - "Welcome Back Kotter" More detail here: Welcome Back, Kotter - Wikipedia, the free encyclopedia
Horshack the character referenced had a particular way of addressing Kotter when he didn't get things. Your English/American is just fine.. Anyone born after about 1980 probably would not catch the reference either. It is very specific to the era, I can't bear to watch the reruns.. (OK, he really isn't that bad. )
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#13366 | |
Once again: "There is no need to reduce the distortion in well designed triode stage". |
#13367 | |
It's an enigma to non-Americans. |
#13368 |
I thought it might be, hence the post..
#13369 | |
However in this circuit I want distortion! The issue is how does feedback reduce distortion. Anyone game for the question, Is distortion from feedback the same as distortion from additional stages of amplification? If so how? If not how? Interesting answers tomorrow. |
#13370 | |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
My guess was based on "gain of each stage is padded down to unity", which may not be quite the case. I guess it's time to get this circuit simulator up and running... Ciao T |
