Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st June 2011, 09:20 AM   #13031
loek is offline loek  Netherlands
Default M800
Originally Posted by Charles Hansen View Post
And I would also be curious to see the schematic.
ラックスマン株式会社|ホーム製品情報|ステレオパワーアンプM-800A - LUXMAN
Only the pics I can understand....
Regards, Loek
Old 21st June 2011, 03:25 PM   #13032
So far, so good, but the 'essence is in the 'triangles'.
Old 21st June 2011, 05:49 PM   #13033
We need more 'info' in order to define this design.
Old 21st June 2011, 05:54 PM   #13034
John the picture looks like SIP package op amps
Old 21st June 2011, 05:58 PM   #13035
Johnloudb's Avatar
yep, I see the little buggers, and sockets no less.
My Website: Hyperacusis, Tinnitus, My Story
Old 21st June 2011, 09:39 PM   #13036
I bet they are National.
Old 22nd June 2011, 03:20 AM   #13037
Chris Hornbeck's Avatar
Hi Ladies and Germans,
Although I'm still working my way through the 13000+ posts in Part Deux, I wonder if it's appropriate to present a circuit element derived from the famous John Curl "boxer" input stage. The circuit is a "boxer" second stage ("VAS" in op-amp speak) with its advantages, although I'm using a half circuit version for a phono equalizer.
If interested, let me know, or if OT, also let me know. I've enjoyed these two threads enormously, and much, much thanks to all.
Chris
Old 22nd June 2011, 03:28 AM   #13038
ostripper's Avatar
Nope , toshiba custom SIP . Same as the JVC super A , custom manufactured for luxman. A good way to keep the IP secret ... put it in a proprietary IC.
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 22nd June 2011, 03:45 AM   #13039
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
John,
The Design is the same "Only Distortion Feedback" as the B1000.
MJ had pretty extensive articles on this. The "Op-Amp" shown is actually no op-amp, but a discrete ciruit.
The "forward" path of the Amp is a simple single ended 2-stage open loop BJT Circuit, driving one side of the output stage with high impedance.
The "Op-Amp" only receives the extracted error, amplifies it suitably and applies it to the other side of the output stage.
Both "Distortion feedback" and "Signal" are mixed at the input of the output stage.
I personally would suggest that contrary to OSTrippers comments the design is quite unusual and interesting. I can see the possibility for it to provide better tradeoffs between "zero feedback" and "ton's of feedback" without attracting the undesirable side-effects of either...
Ciao T
Old 22nd June 2011, 04:33 AM   #13040
I am thankful for that. I would not liked to have been passed over by an IC chip. '-)
Copyright ゥ1999-2013 diyAudio
